Old 04-30-2007, 11:38 AM
Default rod side clearance
I installed my rods and pistons today, as I found out the side clearance of the scat rods with a stock crank (302) is only about 0.011".
How much is recommended? Rev limit will be ~6700RPM.
Thanks,
Simon
Old 04-30-2007, 12:06 PM
Well different people will tell you different things. Most engine books will tell you to stay between .010-.020", but I like to see them around .015-.016".
Old 04-30-2007, 12:39 PM
Rick Parker's Avatar
I am running .022 per pair.
Rick
Old 04-30-2007, 01:04 PM
I assume too much might cause less problems than too little.
Could only 0.010" of clearance per pair cause problems with overheating thrust faces on the rods? Or is it more the lack of oil sprayed on the cylinder walls that doesn't permit such tight clearances?
