Old 07-01-2007, 10:24 PM
onefastmustang's Avatar
Default Weird place for an oil leak....
Or is it..
Every time I think I have all of the gremlins gone I get a new one..
This one is oil collecting on top of the timing cover of my 351 just below the dizzy in a little puddle.. Suggestions as to where that might coming from?? I clean it up, it comes back. I tried tracing the source but no dice.. Is it possible its seeping up through the timing cover like texas tea...
Old 07-01-2007, 10:29 PM
CHANMADD's Avatar
Oil runs downhill,check the dizzy!
Old 07-01-2007, 11:55 PM
Jac Mac's Avatar
Smile
Check the two short upper bolts that secure the timing cover to the block,I find these have a tendency to come loose over time and allow oil to get past the gasket, not sure why but often wonder if its a combo of fuel pump eccentric & pump vibration. A 'nordlock' washer on each should prevent it if this is the problem.
Jac Mac
Old 07-02-2007, 04:49 AM
lovehamr's Avatar
Stolen Avitar
I've had the front intake manifold/block seal right behind the dis. leak and cause that same thing. Did you use the cork gasket or a bead of silicone?
Steve
Old 07-02-2007, 05:08 AM
Manowar's Avatar
All of the above -if no luck, dye with black light.
Old 07-02-2007, 06:54 AM
bobcowan's Avatar
There's a new tool available for finding oil leaks. It injects a petroleum based smoke into the engine. Where the smoke comes out is also where the oil comes out. Takes about 15 minutes to find the leak. Find a shop that has one of these, and pay whatever they're asking. It will save you hours of work.
Old 07-02-2007, 09:16 AM
New tool? I thought Lucas invented something like that years ago. Where the smoke comes out is where the wires leak...
Old 07-02-2007, 01:28 PM
Yah... thats this kit here..
http://www3.telus.net/bc_triumph_registry/smoke.htm
