Old 07-25-2007, 12:58 PM
gumby's Avatar
Cobra Make, Engine: BACKDRAFT
Default MSD distributor problem
the small black contact inside the dist cap fir the coil lead has worn small enough to fall out,
what would cause this ,,or did i just get a defective one.
BDR#397
Old 07-25-2007, 01:02 PM
ENTDOC's Avatar
common problem with that distributor cap
Old 07-25-2007, 01:03 PM
lovehamr's Avatar
Stolen Avitar
I would just replace the cap and not worry about it.
Steve
Old 07-25-2007, 02:43 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
Make sure the rotor is making good contact with it when you put the cap on. If not, it will burn up.
Scott
Old 07-26-2007, 05:54 AM
Roscoe's Avatar
I've got a couple of extra caps if you need a replacement. What model dist?
Roscoe
Roscoe
Old 07-26-2007, 07:31 AM
Rick Parker's Avatar
If you are referring the the small diameter billet distributor you can get a better one from NAPA with brass terminals. KEM (another ignition product maker)also make one. Ask for one for International Harvester V8.
Rick
Old 07-26-2007, 09:00 AM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Dump the MSD cap...I went through 3 of them before going with a NAPA...like Rick said get one for a IH V-8...most NAPA stores have them in stock. Less expensive than the MSD cap also.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 08-18-2007, 05:26 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Son of a Gun! This same thing happened to me today. Took the dizzy out to fix the leak (didn't put an O-ring under the factory ring...used hi temp black electrical tape cut thin to fit in the land of the MSD ring to push out the factory O-ring and installed like this \_______/). Started it up and put the timing light on it and started to turn the dist and it quit!! Ground the batteries dead, then took it all apart again and noticed the coil carbon was flat inside the cap!!! So I'll wax it this weekend, and tune it next weekend. Had to order the part. I'll try the NAPA one next. Thanks for the hint.
