Like Tree1Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #21 (permalink)
Old 04-13-2012, 02:11 PM
Gaz64's Avatar
Originally Posted by wolf k View Post
Connected a vacuum gauge to the tap on the IDF carb, turns out that it is a ported tap. Had a nice steady needle, it was low at 7 in.hg at 1500 rpm, but only drawing from one cylinder. I do have a mild camshaft.
So although you only have 4 ported nipples, if you tee all the ported nipples together, you should get a higher average reading.
Gary
  #22 (permalink)
Old 04-13-2012, 04:31 PM
wolf k's Avatar
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Yes, probably. I was just testing if a single runner would give a steady vacuum signal. I conclude it does, at least with a mild cam. Therefore, I believe, one could run a vacuum advance distributor off a single carb, or runner without the plumbing between multiple runners. You would have to adjust the advance diaphragm for the lower than normal vacuum. I already have a mechanical advance only distributor, so for me it is a mute point, but for a future project perhaps.
carmine likes this.
Rate This Thread:
