| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
05-30-2007, 07:58 PM
looking for 289 Hi-Po heads
How much should I have in the bank to purchase these heads? Are they readily available? Anyone have a set for sale?
Of course it's REAL! You are NOT imagining it!
We don't want a bigger government; We want a government that does a few BIG things, and does them right.
If you think that you can cut it, if you think you got the time, they'll only give you one chance, better get it right first time. 'Cause in this game you're playin, if you lose you got to pay. And if you make just ONE wrong move, you'll get BLOWN AWAY!
05-30-2007, 08:53 PM
Ca
500-1000 + depending on their condition. Unless you are building a "K" motor, save your $$. They offer no performance advantage over standard 289 heads. Valves and ports are the same size. Just mill the rocker arm studs for screw in type and you have essentially the same thing.
Rick
05-31-2007, 11:36 AM
What Rick said!!!!!!!!!!!
But if you have to have them, go to any MCA show or SAAC/Shelby event, check out the vendor row......Last time I was at the Tulsa Shelby event, I saw 6 to 8 pairs of HI-PO heads for sale, some as low as $500.00 per pair..............
And be sure they are real HI-PO heads and not some look-a-likes, make sure they have the "spring pockets" or else they are fakes.......
David
DAVID GAGNARD
05-31-2007, 03:41 PM
Thanks, guys!
06-01-2007, 06:44 AM
MA
Cobra Make, Engine: 289 ERA #2115 under build in my bedroom
289 engine price $2300 ?
Cobra 289 Dudes,
Below is an e-mail of the engine that I'm looking to purchase for $2300.
Is it woth the price?
What Distributer and Carb do you recommend?
Should I use the HiPo exhaust or make my own headers......?
Has anyone used a 351 cam in a 289? What's should I expect form this?
I have a hold on the engine at this time......
289 ERA #2115......... tx mike
This is a rebuilt 1965 Ford Mustang 289. The engine
> was purchased off of ebay by myself then rebuilt by
> a
> professional machine shop. Bored 60 over and
> everyhting new put in to include a 351 cam for added
> power. Complete valve job to include new exhaust
> valves. The engine also has a 1965 HIPO intake
> manifold installed on it. I have used HIPO ehaust
> manifolds (1 from mustang and 1 from fairlane)
> included as well as a used v8 radiator. The engine
> has never been installed, and comes with a 4
> month/4000 mile warrenty from the Machine shop. I
> do
> not have pictures as it has been shrink wraped and
> placed on a skid. I was going to put it in my sons
> 65
> coupe but changed my mind. I have approx 3000 in the
> engine, my loss is your gain.
> Mike, the engine came out really nice. Its
> painted
> OLD Ford blue with aluminum valve covers. I have
> alot
> of parts that go with it and some that were not
> listed
> like the 6 bolt bell houseing and new torque
> converter
> for a c-4, I have the distributer that came with the
> engine, an alternator and the two single groove
> pully's. The ebay add ended and I'm not going to
> relist it at this time. If you decide to buy the
> engine for your project you will not be
> disappointed.
06-01-2007, 08:25 AM
Banned
you've stated in the specs that it is bored 60 over? this is a big no no!! 40 over on these engines is pushing the limit...........but hey what ever floats your boat
06-01-2007, 08:50 AM
MA
I'll check
Thanks....I'll check that out. mike
06-01-2007, 10:56 AM
NY
Cobra Make, Engine: ERA 758 KC Pond 482
FWIW- I had a 289 bored .060" in my 68 GT-350 and ran it 20,000 miles no problems. Everyone warned me about overheating, but it always ran right on the 180 degree thermostat. I believe it is still in the car today and this goes back over 29 years.
Bob
06-01-2007, 06:52 PM
Fl
Cobra Make, Engine: Just a collection of parts right now...
Overbores of .060 are usually the limit. The reason that .040 is recommended as the limit is that if there is a core shift during production, going beyond that weakens the walls. If the engine was sonic tested and bored properly, it is probably fine. YMMV.
06-01-2007, 07:04 PM
Fl
Rather than getting them from the UK, you could check the original source - Dan Gurney's All American Racers. According to their site, there are some NOS units available:
http://www.allamericanracers.com/merch/cyl-head.html
They apparently are being sold through these guys:
http://www.cushmancompetition.com/
06-03-2007, 05:26 PM
MA
Thanks for the 289 .060 feedback. The motor has a warrenty of 4 mos 4K so I'll probably chance it. mike
06-03-2007, 07:41 PM
Oh
Warrenty to the second purchaser? The 4 months don't start until the second purchaser gets the engine? If you haven't done so, you need to talk directly to the builder who is standing behind this warrenty.
Personally I wouldn't trust a 0.060 overbore. It's your roll of the dice though, and life is a gamble. I prefere low risk gambling unless the pay off is big. I don't see the big pay off here. Maybe I missed it, but I didn't see any parts that make this a steal, if the block ends up as toast.
06-03-2007, 08:01 PM
wa
Cobra Make, Engine: FFR Markll non doner build,Ford Racing 392,tremec TKO,8.8w/3;73s,Baer brakes,Black w/silver stripes,w/carbon fiber,gauges,spats,hood soop,door panel inserts.
I have never bored a small block 0.060. Any pro builder will tell you that.
08-15-2007, 09:46 AM
Cobra Make, Engine: Johnex3 427
I have a 67 289, .060 over that I have run hard and as a daily driver with well over 80000 km. Never had an issue with it. I just freshened it up with a new set of rings, bearings, and bolts and it is nice and tight. It is the strongest small block with stock rods and crank I have had over the years.
Now I would bore it to .060 over from stock, but really only to increase the number of times you can rebuild it in the future.
