11-12-2007, 09:56 AM
Which Holley is best?
I've read and re read all the posts on this forum that relate to carbs and have one question.
Which Holley carb is best for MY purposes?
I respect all of your opinions. So let me have it!
302/350 hp FFR with 3.73 rear end. Mild cam, 9.5 to 1 compression.
Tuned for max street driveability. Reworked distributor curve completely.
Have Edelbrock 650 Thunder AVS and can't tune out the cornering stumble and stalling on hard stopping. Slight problems with the secondaries when accellerating, but liveable.
Should I get the Avenger with vacuum secondaries, The DP or the HP with mechanical secondaries. .
This thing will NEVER be raced but will occasionally get nailed hard on an on ramp or away from a light early in the morning. So I want the best street carb available. Looking for the smooth transition from idle to primaries to secondaries under normal driving conditions and at WOT.
Does this carb exist?
Will take all recommendations under advisement but am leaning heavily to Holley. Not opposed to having a shop custom tune it for my engine.
11-12-2007, 10:46 AM
For your application and use in mind, I would go with a 600/650 Holley with vacum secondaries.........Very easy to tune and will be very mild mannered in street/cruising driving.........A 600/650 Holley Double Pumper would be my next choice.......
Have used both on my 350hp, 351-W and now have the 600 DP on......Not a lot of difference in perfomance or driveability from a "seat-of-the-pants" feel for me anyway........
DAVID GAGNARD
11-12-2007, 10:51 AM
What David said is a bulleye.. I'm running a 351Cleveland with a 650 DP. I have a collection of slightly used 750 carburetors for sale..
Dan in Arizona
CCX3209
11-12-2007, 11:01 AM
Dan; I did too, sold most of them or used them for "parts". I did keep my high dollar 750DP from one of the "top" carb builders in the country,(you know, the one that all but ruined a brand new motor), it's primary job for the last 10 years has been a large,expensive paper weight and conversation piece!!!!!!!!!!!!!!!!!!!! live and learn, I learned the hard,expensive way!!!!!!!!!!
My present 600 DP was taken out of a garbage can at a freind's shop,(it is at least 20 years old) he threw it away,said it was no good on his 289.....I took it for parts, once I tore it down, all it needed was a good cleaning and the proper jets..........He had it jetted about 10 jet sizes too rich, guess he thought bigger was better.......
My next best carb was a 600 vac. sec. carb, remanufactered by Holley, bought at Auto Zone............great little carb and gave excellent gas mileage, still have that one.........
DAVID GAGNARD
11-12-2007, 11:06 AM
Not really, what I did was buy the "spring kit" that goes in the vacum thingy. You can get them at Auto Zone or other parts places and then do a little expirementing with your set-up..... Every engine will be a little different.....I changed the spring 2 or 3 times till I found the one that worked best on my car and that was all that was needed..........
DAVID GAGNARD
11-12-2007, 10:55 AM
Won't I have the same troubles with Holley's vacuum secondaries that I had with the Ed. Aren't these cars a little too light to not stumble due to low vacuum at WOT?
11-12-2007, 12:06 PM
Get a Holley Street Avenger. It comes with an assortment of springs for the secondaries. I put in the lightest one and have absolutely no stumble when the secondaries open. I bolted it on and it was jetted perfectly right out of the box (confirmed with a LM-1).
11-23-2007, 03:16 PM
ont
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
I needed to know that too,got good inputs by the guys and you can also go on the HOLLEY web site. They have an awsome site where you can choose the carb. and intake for your application. It will tell you at the end after answering the questions exactly what size of carb you need. I did it and it confirmed exactly what some pro builders where recommending for my stock 302. A Holley 570 cfm street avenger.
11-23-2007, 04:00 PM
Ga
Cobra Make, Engine: Shell Valley
I recently bolted a Holley 670 cfm Street Avenger on to my 351W and right out of the box it was perfect. For the money and ease of installation, you can't beat it.
11-23-2007, 07:43 PM
Az
I wouldn't put a Holley on my lawnmower.
http://braswell.com/
11-23-2007, 09:10 PM
Mo.
Originally Posted by Cobrabill
Way to contribute and offer some helpful info.."Billyboy". I guess you have a Ford lawn mower?
I have a set of twin 750's on my SO, it's all about balance. My engine runs very well on the front single carb around town.
When you stick your foot in it the second carb wakes up and offers the muscle, balancing your carbs in a progressive manner will make you smile if done properly.
Keep tweaking the progressive linkage, a quarter turn on the linkage adjustments rods can become important
Where do you want it to kick in and at what RPM?
11-23-2007, 09:59 PM
WA
Cobra Make, Engine: ERA FIA 2095, 331, w/ TKO 500
I'm running a 750 holley w/ vac secondaries on my 331 ci/400hp. It couldn't run any better. I have an Edelbrock dual plane intake and Edelbrock performer heads. The engine breathes very well. Everyone said the 750 would be too big. I agree if it was a DP. But since you drive around town on the front two barrels, it's perfect. If you put your foot in it, you get all 4 barrels and go like hell. Remember Shelby put 715 DP's on the GT-350 and it only had 289 ci and 305 hp. I think todays intakes and heads breath better than the old hipo fords did in 1966.
11-24-2007, 07:22 AM
Az
Exactly what part of www.braswell.com didn't you understand?Holley sucks.They didn't used to-but they do now.
By posting the website that allows people another choice.Which is known on our planet as HELPFUL INFO.I'm not familiar with the customs on your planet...sorry.
One more thing-Stick the "Billyboy" comment up yer a$$.
11-24-2007, 09:34 AM
Holley sucks.
That must be why they are the #1 supplier of aftermarket carbs. and why the vast majority of Cobra owners run them. It's usually a lack of tuning skills or starting with the wrong carb. in the first place
11-24-2007, 05:07 PM
Az
Tuning skills can't over come junk.And the fact that the vast majority of Cobra owners run would have nothing to do the fact that Holleys came on Cobras in the first place would it?
11-24-2007, 03:57 PM
Mo.
More quality commentary from the self proclaimed "merchant of cool".
You rip Holley and post a website, way to contribute. Sheesh
11-24-2007, 05:15 PM
Az
What's the matter..........own stock in Holley?Angry that they're in financial doo-doo?Todays Holley is but a shadow of its former self.
Everytime you open yer yap(post) the aggregate I.Q. of Club Cobra drops 20 points.
Why does it bother you so that i'm much cooler than you?
JHV48-do a search on this site about carbs.Plenty to read.Out-of-the-box Holleys AND BGs have been known to have metal chips in them.Lack of QC.Pro-systems is another option.Theirs is Holley based also.
11-24-2007, 06:11 PM
Did you mean "merchant of TOOL"?
11-24-2007, 12:02 AM
Cobrabill....
The carb you are trying to sell looks suspisciously like a Holley knockoff!!!
I think like said above a 600 or 650 DP would be purfect.
11-24-2007, 07:25 AM
Az
Originally Posted by CHANMADD
Cobrabill....
Sorry,but Braswell used to do developement FOR Holley.None of the parts on a Braswell are from Holley.Oh,and BTW-i'm not selling anything-just recommending a carb that is superior to a Holley in every measurable way.
