11-24-2007, 09:08 AM
WI
Cobra Make, Engine: Midstates chassis, IRS, 408W, Alu heads, Webers.
OK, so we know that a lot of the guys are running stroked 351W blocks. We know its safe to go to a 408 (keeping the stroke under 4") Knowing that you have a budget (we all do) I would think the best options is to purchase a good 408 Stroker kit. Get a good kit that uses good parts. You wont be disappointed... I personally met a guy with a 351W stroked to 427. This short block was pro built. The guy didnt beat on the car but after about 2 years (summer use only) one of the pistons pushed a hole through the side of the block. He suspects this is from the heavy side load from the 4.170 stroke.
This is the reason that I decided to keep the stroke under 4" (personal preference).
11-26-2007, 07:38 AM
oh
Cobra Make, Engine: Superformance #046 Dart 427w
I got on the stroker heaven website. They have a 351/434 stroker kit using a Scat crank with a 4.000 stroke. Seems it would be safe to put this kit in my stock SVO block, being that it is at the 4.000.
www.strokerheaven.com
11-26-2007, 03:15 PM
WI
Wow, thats a lot of CI from a 351. You may want to check out the required bore for that monster. I guess you would also want to check the max allowable bore for your block. Would you be pushing your block to its max bore with this kit????
11-26-2007, 07:52 PM
Il
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
What, are you just looking for trouble?? Check out the bore on that kit, 427supr. You aren't going to be able to do that with your block.
I don't get it. Do you have something against a 408, or what?
I'm done trying to talk you out of doing too much. -Your money, your engine my man.
11-26-2007, 08:45 PM
VA
I just took a look at this site. Here's a quote from the first page under the section:
"IMPORTANT INFORMATION! PLEASE READ!"
>>Some large Ford stroker engine kits (& other brands) may require stroker pans and the use of a aftermarket block. <<
11-26-2007, 08:55 PM
Il
11-26-2007, 11:02 PM
CO
Can't be done with a stock block. To get 434 cubes with a 4.0 stroke, you'de need a 4.250 bore. Good luck getting that out of a stock block. That's the max recommended bore for a Dart block.
11-27-2007, 05:14 AM
oh
You guys were all belly aching about going over the 4.000 limit on a stock block. I find a 351/434 with a 4.000 stroke and now it the bore size. What's next, the spark plugs won't fit. I'm just kidding! Thanks for the info, I probably go with a 408.
11-28-2007, 11:43 AM
oh
Ford Motorsport website claims that their 351 based "sportsman" block can be bore/stroked to 427 ci. I believe it is a 2 bolt main. When you guys talk about a stock block, are you talking about a 351 "sportsman" block or your run of the mill Ford 351 block? My engine is a 1995 Ford SVO crate motor. Did Ford SVO make a "sportsman" block in 1995?
11-28-2007, 04:17 PM
CO
No, I believe the SVO motor was based on the marine block. Essentially a heavy duty version of the stock block. 427 is about the max cubes for that engine.
http://www.mustangandfords.com/techa...ine/index.html
Like I said, I'm not afraid of a stock block 427 stroker. As long as you keep a good oil supply and keep the rpm's below about 6K it'll be fine.
11-28-2007, 04:38 PM
Cobra Make, Engine: TBD
Yo 427,
I second, third etc. the opinion that a new block is the way to go. I went with the Dart Aluminum for my GT40.
Here's a pic......Oh yeah Webers too.
And a stroked 351 to 418 with downstacks, fuel injection etc. for the Daytona...
The Daytona engine was and is scary fast 560 HP 580 ft. lb. torque, the GT is a work in progress but, I have high hopes.
TR
11-28-2007, 04:55 PM
oh
That's a beautiful engine. I going to play it safe and go with the Ford 408. An Eagle 408 kit can be bought for around $900.00. That to me is affordable HP.
My wife finds beauty in jewelery. I find beauty in car parts. God definitely created men and women different.
11-28-2007, 05:23 PM
WI
427Supr
Good choice !!! It will be plenty of power and very dependable!! Although... I really liked the looks of that Dart Alum with webers....mmmmm How about a little less jewelery and a few more car parts.... Just kiddin. Let us know how it works out.
