Old 04-04-2008, 09:29 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Default Solid lifter valve lash adjustment help.
I looking for a sequence to adjust the valve lash with solid lifters on a 1969 Ford 302. If you start with #1 cylinder at top dead center, what other cylinders will be on the back side of the cam lobe? Then you rotate the crank 90 (or 180?) degrees and you can adjust another 2 cylinders, rotate another 90 degrees and adjust another 2 cylinders, etc., etc.
Snakebit
