Old 01-12-2009, 12:17 PM
Cobra Make, Engine: KCC 1991 - 302 Ford windsor
Default 302 or not?
I need help in checking my engine number, i havent actually checked the number myself but on the invoice dated 1992 it says CR1102X, can this be right?
Old 01-12-2009, 01:12 PM
Woodz428's Avatar
I would guess that's someone's inventory #, it's not a Ford #. Look above the starter on the block and that will be the location of the block casting #, that should help verify size & year.
WDZ
Old 01-13-2009, 01:19 AM
PANAVIA's Avatar
if you find part numbers on things (ford made things ) they can be decoded on when they were made and i am sure you can decode the engine castings on WHAT they were originally made for, but then who knows what they did with it.
http://www.fairlanet.com/partnumbers/
Old 01-13-2009, 11:25 AM
Thanks guys, it is not possible to get to the number ontop of the starter, perhaps with a mirror but i found on the block behind the intake manifold FR1162X
Old 01-13-2009, 12:10 PM
Woodz428's Avatar
First, it is unwise to start 2 threads with the same question...especially if you ever want an answer..and, again, NO that is not a Ford #. Unless you look above the starter, slide under the car and look up no mirror needed, you are just wasting people's time. I imagine that may be a Ford Racing #, that would indicate a build, however that isn't for certain. The # above the starter IS.
WDZ
