Old 02-12-2009, 10:29 PM
Cobra Make, Engine: Pacific Roadster, 427 stroker, TKO 500
Default Oil Pan/Scatter Shield
Need some info on what oil pan and scatter shield to use on a 427 stroker(351w based).
Old 02-13-2009, 06:54 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
I can tell you what I did and why. My block is bigger in some areas because it has 4-bolt mains. Canton and a few others make oil pans to fit this block but I went with a marine-style pan from Armandos that was about $100 lower priced and is lower in profile for the same capacity as the sump-type pans. If you're using a factory 351W block any good performance pan will work.
I went with the McLeod scatter shield because it supposedly doesn't need to be aligned, but time will tell. The Quick Time shield seems to be very popular lately but it wasn't available when I was buying parts. I hope this helps. At any rate, good luck with your build.
Bill Stradtner
Old 02-13-2009, 07:49 AM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
sllib,
Does Armondos have a wb page? Also I am in VA Bch and have a Dart block, I would like to come by an check out your oil pan and car. PM me if this is ok with you.
autobody prof.,
I went with a Quick Time B/H and a Canton pan, the pan does sit very low....Mike
Old 02-13-2009, 09:49 AM
xracerbob's Avatar
Armondo's-
http://www.geocities.com/motorcity/flats/1624/
Old 02-13-2009, 07:10 PM
Thanks for the info guy's. I will look into both. Does the Quick Time have to be aligned?
Don
