Old 03-04-2009, 09:50 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Default Distributor gear on MSD 8478
I have an MSD 8478 on my motor. Does anyone know if it is Comp Cams Roller cam compatible or do I need to change the gear?
Thanks
Mike
Old 03-05-2009, 05:31 PM
Well it seems that no one wanted to touch this one. The answer from Comp is best to use a bronze, then if you call back and get another helper it's steel.. useful. Anyhow I called a few engine builders and got some input from someone here and they all said steel. So that's what did.
Old 03-12-2009, 02:49 PM
donraye's Avatar
Cobra Make, Engine: Street Beast "Grabber Orange"/Silver stripe w/418W 520HP full roller, T5. and: Backdraft #814 RT3B "Black Label" "Magic Black"/Sterling Grey stripe, 408W, full roller, 475HP, T5
Default Phenolic!
Thanks
Mike
I have the same distributor and just installed a new Comp Cams phenolic gear on it to go with my Comp Cams steel core Hyd. Roller.
If the cam is steel core you should use the Comp Cams Phenolic, If it's iron core use the Bronze.
Don
