Old 04-24-2009, 06:21 AM
WildBill3's Avatar
Default ? Is ther a slightly longer starter nose
Hey im using a block plate on our TKO600/408 engine package and we run an old style large starter but I hardly get any engagemnt of the starter to the ring gear because of the block plate do they make a different nose for this starter to help get Full contact with the ring gear.Im afraid I already have a bad spot in the fly wheel from this. i had to slightly rotate engine out of that spot to get it to start the other day.thanks in advance for the Help!!WB3
I agree Life is way to short to worry about gas milage.Other rides Crewcab Super Duty F350 Ford,Shlby Charger,66Mustang/Frankinstang,Chevy Van,KTM Dualsport,FFR Daytona Coupe SOLD... RUN N GUN 06,07,08,09 Hallet 09,
Old 04-24-2009, 09:21 AM
Cobra Make, Engine: B+B 351w #112
There might be a difference between a starter for an automatic and a manual. Jim
Old 04-24-2009, 10:20 AM
DAVID GAGNARD's Avatar
there definetly is a difference in "nose" length on a starter for a manual and an automatic.......that's why I now have a spare starter I can't use........
DAVID GAGNARD
Old 04-24-2009, 11:11 AM
WildBill3's Avatar
Thanks I thought for sure I told them we were running a TKO at the Starter company we deal with.Thanks again for the info...Bill
Old 04-24-2009, 11:25 AM
SSSammy's Avatar
Bill, I ran into a similar problem on my FE with the Tilton Super Starter. Tooth engagement was just short of the spec. As recommended by Tilton, I took the faceplate of the starter off and had it machined .060" thinner. Problem solved!
Sam
Old 04-26-2009, 12:45 AM
WildBill3's Avatar
Wow thers an idea I hadnt thought of thanks Sssammy!
Old 04-26-2009, 04:28 AM
Default Any thoughts on a mini starter Bill?
WildBill3 Bill any thoughts on a mini starter? Call Summit of Jegs for INFO ONLY. I would try and e-mail Keith Craft or Brent B. to check with. Either one should have the correct answer. Years ago They had short nose, long nose, manual, auto trans, & heavy duty starters all would work on the same motor and flywheel. If worst comes to worst, machine out the backing plate where the starter is mounted. Or machine the mounting housing on the starter. This will void the warranty. Rick L.
Old 04-26-2009, 07:23 AM
WildBill3's Avatar
Thanks Rick I never realised ther were so many...
Old 04-26-2009, 10:26 AM
Dwight's Avatar
Smile got to love it
wildbill3
don't you just love this forum????
Dwight
Old 04-28-2009, 05:21 PM
WildBill3's Avatar
I do thers soo much knoledge out ther it's nice to be able to tap into and not going it alone,We ran a FWD racer in the early 90's and had the "Inderect connection" from Mopar to call, justa guy reading out of a book on the other end wow great help NOT.Again thanks to all those who help us the unknowing WB3
