| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
04-29-2009, 06:27 PM
ca
Cobra Make, Engine: CRII with a Stroked Windsor
Are these gaskets really reusable??
Milodon claims it is reusable... Is it really?? Anyone ever used one before?
http://store.summitracing.com/partde...4&autoview=sku
04-29-2009, 06:51 PM
Yes
Yes
But I didn't like them, they leaked like crazy, it was about 50/50 the guys I talked to that used these gaskets and still use them....50% swore by them and the other 50% swore AT them!!!!!!!!!!
I was in the latter group,as usual!!!!!!!!!!!
In talking to others, I've seen the chevy guys are having better luck with them than the ford guys....
David
DAVID GAGNARD
04-29-2009, 06:54 PM
KS
Cobra Make, Engine: jbl
i've used something similiar on valve covers if it is the stuff i'm thinking about and didn't like it. the rubber gets squishy and doesn't hold. i prefer the "right stuff".
04-29-2009, 07:02 PM
ca
I have one of these and I am going to drop my oil pan tommorow due to a leak.. Debating on what to do with the gasket. Reuse it or replace it with something else. Not sure if the leak is from the pan or front seal. But I might try right stuff instead of the gasket if that is what others use.
04-29-2009, 07:18 PM
KS
right stuff, expensive, but beats taking the pan off
down side, i needed to take the pan off after the motor was installed in the jbl, couldn't pry it off.
04-29-2009, 07:53 PM
VIC
Corker
I have used these for valve cover also.
I had to remove the 'lip' from some parts of the valve cover that would have retained the cork gasket on my old M/T cast ally valve covers - I have generally been very happy with them and found they last if you dont over-tighten.
(unfortunately my VicJr heads had a bolt hole in the wrong spot & the gasket wouldn't work - reverted to cork  )
LoBelly
05-03-2009, 08:58 PM
ca
I have the milodon "reusable" gasket but I am opting to not reuse it.. what would you use with the milodon pan?
1. Cork
2. Rubber
3. RTV/Right Stuff
4. Other
The reason I ask is I aways seem to get a little bit of small seep from the oil pan. Especially after a bit of rough driving.
05-04-2009, 06:29 AM
KS
no brainer here, i would do the right stuff. just make sure the bead is big enough and surface prepped.
i'll bet a $5 you use the gasket and it leaks within the year, it would for me anyway.
05-04-2009, 07:37 AM
ca
I am leaning that way.. I am just worried about the front and rear hump.. I assume you apply it to the pan instead of trying to fight gravity and put it on the block..
05-04-2009, 08:10 AM
KS
nope, put it on the block, it'll stick. i would set the pan on the block and outline with a marker where the pan sits so you put the sealer in the right places, also look at the ends to see how much gap to fill. hump it up over the crank when you apply the bead and make sure to apply plenty. i would let it sit overnight personally.
reason i had to take my pan off is i didn't follow the pan rails well enough around the corners.
05-04-2009, 08:19 AM
I use a cork gasket with grey rtv and never ever had a leak. I the rtv on either side of the gasket. to get it off can be a bear, you have to pound a putty knife between the pan and block and eventually you will get it off
05-04-2009, 08:57 AM
KS
i'm writing as if the motor is upside down, if in the car you'll have to put the stuff on the pan. don't fight gravity, it's a losing proposition.
