November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
  #21 (permalink)
Old 06-05-2009, 11:38 AM
eschaider's Avatar
Originally Posted by RedBarchetta View Post
If it was my motor, that was my initial thought (after pulling the dist. and verifying that the pump isn't generating oil at the valve rockers). I would also be thinking, while the pan is out, to pull the main caps and insure the bearings didn't get scored. You already have too much time and energy building the motor...I would always be wondering whether or not the incident hurt the bearings. It doesn't take much and they don't cost a whole lot in the end.
-Dean
+1
Thanks Dean. You're dead on target. Easy check and well worth the effort. Good preventative maintenance at this point.
Ed
  #22 (permalink)
Old 06-08-2009, 09:29 AM
Finally dropped the oil pan this weekend and found the clip which slides on the oil pump shaft had worked its way downward and allowed the pump shaft to move up out of the pump causing the oil pressure loss. I was able to install a new shaft and clip and with the oil pump primer I was able to get 50 lbs of pressure. Thought all was good. I am not able to remove the pan completely due to the Heidts crossmember so I was not able to inspect the bearings. After reinstalling the distributor fired it up and unforunately only have 10-15 lbs of pressure at idle now. If i rev it up I do get 50 lbs. Short loss of time with 0 pressure killed the bearings. Engine coming back out for new bearings. Thanks again for everyones input.
Rate This Thread:
