Old 06-07-2009, 08:15 AM
Cobra Make, Engine: Classic Roadsters, 351W
Default M-6010-N351 w/ Hydraulic Roller Cams
I purchased a M-6010-N351 block from ford racing and was planning on putting in a hydraulic roller cam. The block does not have penetrations in the lifter valley to attach the lifter guide plate. Is the guide plate needed, or do I have to machine additional holes in the block to attach the lifter guide plate?
Old 06-07-2009, 08:35 AM
To use the OEM style roller lifters you have to machine the block. I think it is a pretty simple thing that most any shop can do. I don't think is is too costly.
Old 06-07-2009, 02:53 PM
PANAVIA's Avatar
use the spider as a template and use 1/4-20 bolts - no biggie.
Double check dog-bone/fork alignment for each pair of lifters. you may have to do some minor clearance work. --again no biggie.
Old 06-08-2009, 06:17 AM
bobcowan's Avatar
Or, you could use a link bar lifter. If the engine is already assembled, you probably don't want to be drilling and grinding on it. A lot more expensive, though.
Old 06-08-2009, 06:17 PM
DAVID GAGNARD's Avatar
I just use the link-bar lifters,too easy, did it on my last 2 motors.........(even a cave man can do it)
DAVID GAGNARD
Old 06-09-2009, 08:06 AM
Default Which do you suggest?
I see the Ford Racing M-6500-S58 and the COMP Cams 8931-16. Which do you suggest, or is there another you prefer?
Old 06-09-2009, 09:01 AM
Edit...I thought you were showing the lifter spider.
I wouldn't spend $400-500 on lifters guys. You can get the OEM lifters for $120 + $40 for the spider. It literally takes 30 minutes to drill/tap the bolts for the spider.
BTW, don't drill a thru hole....you'll be drilling into a cam bearing/cam bearing journal.
Old 06-19-2009, 12:20 AM
PANAVIA's Avatar
i would go stock as well. -- the bumps for the spider should be there in the N351--
Old 06-19-2009, 04:11 AM
Hi,
I stock link bar lifters from Comp Cams & Ford.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 06-19-2009, 09:02 AM
Hi,
The Comp Cams 8931-16 roller conversion kit I want to sell for $450.00.
Summit has them @ $529.95
http://www.summitracing.com/parts/CCA-8931-16/
40 Pearl St
fortesparts.com
508 875 0016
Old 06-19-2009, 11:21 AM
Default I am trying making the spider work
I was surprised, but the B50 & B58 blocks (Amateur Competition) do have provisions for the spider, but the M&N351 (Professional Competition) do not (go figure). I didn't realize it until the short block was assembled. We had to grind down some raised lettering in the lifter valley and hand drill holes to accept the screws for the spider. The holes still aren't tapped since our tap & dye kit tapers down, so at the current depth of the hole the tool bottoms out in the hole before it removes material for the threads. I am a bit scared to just drill deeper because I don't want to end up making a through hole in the block. I am considering grinding down the tapered end of the tap & dye so it is more square and will remove material for the threads sooner.
Old 06-19-2009, 12:59 PM
bobcowan's Avatar
spend $10 and get a bottom tap. You'll get much better results, and won't ruin your standard tap.
