Go Back   Club Cobra > General Discussion > Suggestions
Old 07-10-2007, 03:45 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Default Pictures will not load into my gallery.
I've done this more than a hundred times with no problem, but now it says they have been uploaded successfully, but they do not show up.
Old 07-10-2007, 03:54 PM
computerworks's Avatar
That will usually happen when the images are way too big for the Gallery.
...the software doesn't follow through with the upload.
Check that your pics are no bigger than 200k in file size, and you should be OK.
ron
ClubCobra Moderator
Old 07-10-2007, 04:01 PM
Burgs's Avatar
Thanks Ron. New cammera took 2.9 mb pics, which is bigger, right?
Brad
Old 07-10-2007, 04:09 PM
Yup... I was even going to say, "Didja get a new camera...?"
Try the photo resizing tool I posted and resize those megapixel images to 800x600 or 1024x768 and you should be OK.
Tips on Picture Uploads and Image Sizes
Old 07-10-2007, 04:11 PM
Burgs's Avatar
Thank you Ron, that did the trick!
Brad
Old 07-10-2007, 04:18 PM
wtm442's Avatar
Beam Me Up Scottie
Brad
You can also change the file size of the pictures thru the camera menu. You only need 3 mb files if you are going to print high quality 8 by 10 photo.
Warren
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
It's because you are from Michigan.
Any other state and they would load fine.
Old 07-10-2007, 04:27 PM
Burgs's Avatar
Originally Posted by wtm442
Brad
It's a new camera, and an easy setting to change, Thanks.
Old 07-10-2007, 04:33 PM
Burgs's Avatar
I guess I have that Texas, bigger is better mentality,... speaking of that, how's your new, old motor coming along?
