11-15-2009, 10:15 AM
Mn
Cobra Make, Engine: SPF 1233-396C.I. Windsor
Buzzer w/ Key-on?
We are finalizing a new install on chassis # 2590. This is a car from D&M and had been in inventory for quite awhile. When you turn the ignition key to the "on" position there is a buzzer or alarm from under the dash. What the heck is this and when was it added? Thanks, Mike
Mike Beamish / Northern Racing Products Superformance service & installation.
11-15-2009, 10:41 AM
Is the brake reservoir filled? There is a buzzer to indicate low brake fluid.
Doug
11-15-2009, 11:25 AM
Mn
It was that simple- in the 8 yrs we have worked with this product, this is something I had not encountered. It was actually above the low level mark but still activated the alarm. Thanks! Mike
11-15-2009, 06:38 PM
Good tip Doug !
11-15-2009, 08:03 PM
Cobra Make, Engine: SPF#0760
Yes, only one factory installed buzzer on a chassis...
It will also trip if your brake fluid is low and you are doing some spirited acceleration, deceleration or corning. A great indicator that it's almost time for break pads.
SPFWiringDiagrams@Comcast.net
11-15-2009, 08:07 PM
Is there a float mechanism in the reservoir that triggers that?
11-16-2009, 03:24 PM
Good to know. I have had the buzzer come on when accelerating up my road. Never knew what the hell it was because all the gauges were reading good.
11-16-2009, 04:05 PM
Banned
Wow, Patrick, another feature that the ERA doesn't have.
11-16-2009, 04:07 PM
Originally Posted by RedBarchetta
Wow, another feature that the ERA doesn't have.
Well I'm sure if I requested it they would be happy to oblige.... It sounds like more of a PITA though that a good feature. Does it use a float in the reservoir? Or something else?
11-16-2009, 04:19 PM
Banned
Patrick, I find it entertaining that you read and react to the Superformance threads as much as the ERA ones. You're too anal, dude...loosen up!
11-16-2009, 04:21 PM
I guess you don't know how the sending mechanism works, huh?
11-16-2009, 04:30 PM
Regularly Offensive
Cobra Make, Engine: spf
It is a superformance secret.............
float
Ed
Too close for missles, switching to guns.........
11-16-2009, 04:32 PM
float
Thanks. I wonder why I catch so much shi* on this particular forum?
11-16-2009, 04:34 PM
Regularly Offensive
It is fun..................it is a fun forum......
Ed
11-16-2009, 05:59 PM
Banned
It's a function of how much you toss into the fan, really.
11-16-2009, 06:02 PM
But I mean no harm.
11-17-2009, 06:36 AM
No, there is a little man in a small boat inside each reservoir, at a low fluid level he sounds an alarm. On early SPF cars he used a bugle, but it was difficult to hear over the engine sounds, so they changed it to a float with a buzzer. The design was upgraded on all cars by the factory - no charge. All the little men are all retired now, and living in Arizona...the small boats were all sold on eBay...
11-17-2009, 07:56 AM
Banned
Blas, ROFLMFAO!
11-17-2009, 08:25 AM
Dang, that gratuitous ball-busting got better with each edit.  And I was only curious as to how it worked; we haven't had any really interesting mechanical issues around here for a while.
11-17-2009, 09:57 AM
That's a classic retort. Can we make that a sticky? Patrick was one-up'ed.
