04-25-2010, 01:49 PM
Be carefull you may have to get the rivits out some day. I would sugest using a toothpick and placing some clear silicone in the hole than pushing the rivet in. You do not want the silicone overflowing on the paint so a little is better than alot. You will also notice the rivets aren not concentric or perfectly round you may be able to rotate the riviet to get a tigheter fit or gently squeze the bottom to make oblong and push in.
