Old 12-03-2009, 03:37 PM
JA COBRA's Avatar
Cobra Make, Engine: superformance 460/ stroked to 521
Default Spf hard top camlocks
I have a hard top for my spf that i just bought but i do not have camlocks for the rear.I have them on order from hillbank,does anyone have pics showing them installed on the roof. I am just wondering how they hook up or install.
Thanks in advance
Old 12-03-2009, 06:01 PM
dont's Avatar
Cobra Make, Engine: SPF #1235
I use 3.75 x .375" bolts with wingnuts on mine. Be sure and put a spacer such as a nut inbetween the top and the ferell on the car. The rubber seal should just sit on the car not crush flat. Also put masking tape or something under the rubber seal to keep it from scratching the paint.
Don
Superformance #1235
460/T5
Old 12-04-2009, 04:38 AM
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
painters blue tape also works as a deck protector - trim to not let the tape show if concerned about appearance . also, thin foam rubber type material works too to protect the paint from hardtop seal or soft top where the lift-a-dots are . Bill
Old 12-04-2009, 11:36 AM
Jim Kellogg's Avatar
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
I have been running the SPF hardtop for several years, and will take photos of my setup if you need to see them.
First question...
Is it a SPF factory hardtop?
Secondly, if so, has it already been fitted to your car by a SPF dealer?
These are 2 important points we will need to know to be able to help you with your setup. The SPF hardtop "initial" install is best done by a dealer who has done it before. If not, I can help walk you through the setup process.
Jim Kellogg
Breesport, NY
Old 12-04-2009, 02:54 PM
JA COBRA's Avatar
Hey Jim
Thank you for your reply,yes could you please take some pics of the camlocks in place.It is a spf hardtop.Your info would be greatly appreciated.
