December 2025
Old 02-01-2010, 08:48 AM
Got the Bug's Avatar
Jim,
How did you determine that there is an additional 1/4" of travel in the clutch fork and that you're not getting full engagement? For some reason, they installed the same type of slave on my car (I've also got a Roush, TKO600, and a Quicktime), but it has worked fine so far.
Doug
Old 02-01-2010, 10:30 AM
Originally Posted by Got the Bug View Post
Jim,
When I adjusted the M/C rod in the footwell as tight as I could (no freeplay whatsoever), then the grinding stopped, but just barely!
I'm going to try putting a thick washer between the fork and the end of the rod to get some additional length and see if that cures it. If so, then I will fabricate a longer rod and use lock nuts to adjust and secure it to the fork.
Jim
Rate This Thread:
