LinkBack Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 02-28-2010, 04:43 PM
mattpatt's Avatar
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Default SPF ceramic coating vs Jet Hot
How does the SPF ceramic exhaust coatings hold up (black and silver)? Heat induced apprearance changes? Any recommendations on black vs silver (except initial color preferrence)? Also, I assume the SPF ceramic coatinga are the same as Jet Hot coatings. Correct? Maybe can save some $s here.
Old 02-28-2010, 05:51 PM
Both are ceramic coatings. As with some many things the product is only as good as the person doing the work. If done correctly will hold up for years and years, if not then you will probably see some light surface rust.
Old 04-06-2010, 01:31 PM
But look that black SPF (SPO between 2100 and 2300):
http://cid-801515003f0acfe4.skydrive...blc%5E_cob.png
Has a Rush 427SR engine. It it possible to bing the color back to black?
Juergen
Old 04-06-2010, 02:08 PM
Don Don is offline
Swain Technology's version of ceramic coating, texture of semi-rough sandpaper ( ceramic particles ) in white only. Can be sprayed black with high temp paint. Process is not licensed to franchises, they are located in upstate NY. Had two different sets of headers and side pipes coated by Swain, excellent results.
http://www.swaintech.com/store.asp?pid=10969
Old 04-06-2010, 02:33 PM
btw. it has around 2000 miles on the gauge. Any idea, what causes the sidepipes so burned?
Thx, Juergen
