04-02-2010, 12:31 PM
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Rear view mirrors
Is the passenger side mirror actually useful? Also, I've seen cars with the main rear-view mirror mounted on the dash or higher at the top of the window. Any preferences?
thx
04-02-2010, 01:08 PM
A bullet mirror on the passenger side is useless. A small suction type rear view mirror in the upper RH corner of the windshield works much better.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
04-02-2010, 01:34 PM
Regularly Offensive
Cobra Make, Engine: spf
These mirrors were actually funtional.
Ed
Too close for missles, switching to guns.........
04-02-2010, 01:52 PM
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
Hey, I remember that Cobra. Nice paint job!
Some cobras have a 1/2" spacer (or so) to raise the dash rear view mirror. depends on your seating position and preference. I'm using a MG or something like that, a little taller with a slight convex curve.
Dark Water Customs makes a mount for the top of the windshield if you want to relocate your dash mounted mirror. I've always wondered about vibration.
http://www.darkwatercustoms.com/purchase.php
I've seen owners (like John Marsy's JBL) use the SPA race mirrors for center and side - Great mirrors. I switch to the GT side mirrors for track events.
http://www.pegasusautoracing.com/adv...RORS&iorb=4764
 Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
04-02-2010, 04:11 PM
Regularly Offensive
You should Ron, I stole the color combination from your car. The mirrors are raydot with windscreen adapters.
Ed
04-03-2010, 07:40 AM
Ed, did a web search for " raydot with windscreen adapters " and the only item was the Finish Line Side Post, which does not appear to be the same as you mentioned/pictured.
Do you have a source for the " windscreen adapters " ?
............thanks
04-03-2010, 08:54 AM
Go to Pep Boys and get the nanny mirror. It's 6 bucks or so and attaches with a suction cup. Gives great all around view.
04-03-2010, 10:43 AM
Bob, thanks, had previously obtained, keeps falling off. How did you secure yours ? The one I have has a lever for activating the suction.
04-03-2010, 11:03 AM
There's always the Japanese solution, which puts oversized rearviews on the midpoint of the front fender...
I've found I can adjust my driver's side Raydot (emphasis on the "dot") and dash-level center mirror so that I can see what's behind me... but it is like peering through a pair of portholes.
04-03-2010, 11:11 AM
This clip on Convex mirror was recommended to me by someone on CC. You can buy it on eBay (Broadway 240mm).
Works great. The only thing I don't like is that they printed the name on the mirror. The frame is black so it blends in. Looks a little out of place, but it doesn't stick out that much. That and the convex mirror in side mirror is perfect.
Doug
04-03-2010, 11:49 AM
I have the standard middle rear view mirror at the top of the windshield and it works fine. No vibrations. It is the same mount as Doug shows, except the use of glue to the glass. It is not a suction cup to the glass. It is similar to the common glass mount found on most common factory cars. I think I could use a larger mirror like Doug's!
04-03-2010, 02:31 PM
Regularly Offensive
Don, they are the same ones from finish line. I just tweeked them a bit. The raydots mounting bolt was extended one inch by welding a bolt to it. One half inch aluminum tubing for the spacer.
Ed
04-03-2010, 04:29 PM
Ed,
I did the same with using bolt/nut "couplers" (instead of welding) from Home Depot/Ace Hardware store and a 1" chrome drain pipe as the cover/extension.
Lots of stores sell RayDots. couldn't use the Broadway Wide mirror - too much vibration. Maybe I should bet a smaller motor?
Still driving the Jag?
 Ron; SF_SN888KE
04-03-2010, 05:30 PM
Regularly Offensive
Nah, looking for something else these days.
Ed
04-05-2010, 03:18 AM
Step on the gas and look over your shoulder.
04-05-2010, 05:55 AM
NJ
I have a dash mount rear view mirror. When seated in the car it blocks my view over the right fender. I like the idea from Dark Water Customs using a brachet to mount the mirror on top of the windshield.
 Snakebit
04-26-2010, 07:13 PM
Mattpatt, I am a new Superformance owner and went through this issue a few weeks ago. If you want to make the Superformance outside driver's mirror functional, please see the thread "Bad Start to a New Relationship" and, in particular, ztarum's fix. His fix, combined with a convex mirror from Finish Line Accessories, worked for me. You still need to look back, but at least with this fix, the mirror aims at traffic to your left and not to the pavement.
09-07-2010, 05:38 AM
Me
Wow especially liked the Ford commercial took my drivers license test in my Dads 56 Crown Vic wagon with 312 ThunderBird motor in 1964.Too bad his rear tires always wore out prematurely after that.
09-07-2010, 05:43 AM
Me
To all for the great ideas with rear viewing in my Cobra.My dash mount mirror problem is fixed with 2 1/4" extended shaft.Now will play with fender mirror first trying the convex route,then the wing window mirror if all else fails.
09-08-2010, 08:51 AM
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Cannonball Run
I liked what the Italian Ferrari driver said in "Cannonball Run" at the start of their cross country race in New York city... He reached up, grabbed the rear view mirror and snatched it off the windshield mount...throwing it over his right shoulder, as he shouted...
"What'sa behind'a me isss-a not imporrrrtant...!"
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
