Old 09-18-2010, 06:30 AM
Default SPF Turn Signals
Hey all
my turn signals died on me.... with some help from fellow spf owners, I found it was that clear flasher thing under the dash, anyone have a part # so i can get one from Napa or some other parts place?
thanks in advance for the help
Old 09-18-2010, 06:50 AM
Originally Posted by maxum_101 View Post
Hey all
I dont have a specific part number but I belive its just the standard flasher. Just get one with the correct number of contacts.
When putting it in, loosen up the holding piece of metal a little bit so the pressure on the flasher isnt so tight.
Old 09-18-2010, 10:08 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Did you look on your copy of my Wiring Diagram?
All that type of information is there....
SPFWiringDiagrams@Comcast.net
Old 09-20-2010, 09:29 AM
hey Blas, u see i moved 4 mnths ago and well , let just say im still unpacking.... havnt found that box with the wiring diag, haha, but i did get it all fixed up and working, 1 question tho the one i took out of the car has a diffrent part number on it from the new one i bought from the store, does that make a diffrence? the new one works fine, but i just want to make sure.
Old 09-20-2010, 09:33 AM
hi Steve-O
thanks for your reply, it was the holding piece you mentioned that caused all the trouble, crushed the outter plastic case.
Old 09-28-2010, 06:44 AM
Cobra Make, Engine: Superformance MK III 428CJ
The Superformance i just bought has no turn signals, what parts do i need to install them?
SPF # 2156
thanks, marvin
marvin
Old 09-28-2010, 07:38 AM
Blas's Avatar
How can you not have turn signals? They were removed I assume?
Is the connector still at the base fo the steering column, just behind the dash face? Send me an email address and I'll send you a photo of the chassis plug to look for
Old 10-02-2010, 03:15 AM
PANAVIA's Avatar
Classic -- I have had an issue when one bulb does bad the turn signal hangs and wont flash --
Old 10-02-2010, 04:44 AM
Does anyone have a photo of the turn signal stalk?
I called the PO yesterday and he says never had turn signals?
thanks, marvin
marvin
Old 10-02-2010, 05:10 AM
Senile Club Cobra Member
http://www.autohausaz.com/vw-auto-pa...placement.html
Note that the SPF uses a connector plug on the end that VW does not. The correct unit is the "1967" one.
rick@autoventureusa.net
Old 10-03-2010, 04:42 AM
I have that 1967 i guess but it only operates the high beam.
The lever only has two positions it feels like, there is a clear part in tray under dash that looks like a flasher?
PO that bought the car new said never has had signals or at least they did not work?
Guess i need to check further see why the switch seems to only have two positions, also it is on the right of the column, is this correct?
thanks, marvin
marvin
Old 10-06-2010, 02:46 PM
I removed the steering wheel today.
The snap ring that holds the signal stalk was just laying there loose.
Guess I need a drawing, I think someone has had this apart or it was not assembeled correctly.
When I removed the stalk the little contact with spring fell out, I'm not sure the collar that fits inside the stalk and over the steering shaft is oeiented correctly?
And I can understand why the snapring was not in place the left side of stalk collar lacks about 1/32 going down enough to get the ring installed.
Thanks for any advice, marvin
marvin
Old 10-07-2010, 04:22 AM
Blas's Avatar
You never sent me that reminder message...Check your email
Old 10-07-2010, 04:58 AM
Thanks for the reply, will need to wait untill i get time to remove wheel again and i will take photo's.
Not sure if everything is assembeled correctly, or even if all the parts are there.
thanks, marvin
marvin
