| 29 |
09-18-2010, 07:30 AM
Ont
SPF Turn Signals
Hey all
my turn signals died on me.... with some help from fellow spf owners, I found it was that clear flasher thing under the dash, anyone have a part # so i can get one from Napa or some other parts place?
thanks in advance for the help
09-18-2010, 07:50 AM
Originally Posted by maxum_101
Hey all
I dont have a specific part number but I belive its just the standard flasher. Just get one with the correct number of contacts.
When putting it in, loosen up the holding piece of metal a little bit so the pressure on the flasher isnt so tight.
09-18-2010, 11:08 AM
Cobra Make, Engine: SPF#0760
Did you look on your copy of my Wiring Diagram?
All that type of information is there....
SPFWiringDiagrams@Comcast.net
09-20-2010, 10:29 AM
Ont
hey Blas, u see i moved 4 mnths ago and well , let just say im still unpacking.... havnt found that box with the wiring diag, haha, but i did get it all fixed up and working, 1 question tho the one i took out of the car has a diffrent part number on it from the new one i bought from the store, does that make a diffrence? the new one works fine, but i just want to make sure.
09-20-2010, 10:33 AM
Ont
hi Steve-O
thanks for your reply, it was the holding piece you mentioned that caused all the trouble, crushed the outter plastic case.
09-28-2010, 07:44 AM
Ky
Cobra Make, Engine: Superformance MK III 428CJ
The Superformance i just bought has no turn signals, what parts do i need to install them?
SPF # 2156
thanks, marvin
marvin
09-28-2010, 08:38 AM
How can you not have turn signals? They were removed I assume?
Is the connector still at the base fo the steering column, just behind the dash face? Send me an email address and I'll send you a photo of the chassis plug to look for
10-02-2010, 04:15 AM
Classic -- I have had an issue when one bulb does bad the turn signal hangs and wont flash --
10-02-2010, 05:44 AM
Ky
Does anyone have a photo of the turn signal stalk?
I called the PO yesterday and he says never had turn signals?
thanks, marvin
marvin
10-02-2010, 06:10 AM
Senile Club Cobra Member
http://www.autohausaz.com/vw-auto-pa...placement.html
Note that the SPF uses a connector plug on the end that VW does not. The correct unit is the "1967" one.
rick@autoventureusa.net
10-03-2010, 05:42 AM
Ky
I have that 1967 i guess but it only operates the high beam.
The lever only has two positions it feels like, there is a clear part in tray under dash that looks like a flasher?
PO that bought the car new said never has had signals or at least they did not work?
Guess i need to check further see why the switch seems to only have two positions, also it is on the right of the column, is this correct?
thanks, marvin
marvin
10-06-2010, 03:46 PM
Ky
I removed the steering wheel today.
The snap ring that holds the signal stalk was just laying there loose.
Guess I need a drawing, I think someone has had this apart or it was not assembeled correctly.
When I removed the stalk the little contact with spring fell out, I'm not sure the collar that fits inside the stalk and over the steering shaft is oeiented correctly?
And I can understand why the snapring was not in place the left side of stalk collar lacks about 1/32 going down enough to get the ring installed.
Thanks for any advice, marvin
marvin
10-07-2010, 05:22 AM
You never sent me that reminder message...Check your email
10-07-2010, 05:58 AM
Ky
Thanks for the reply, will need to wait untill i get time to remove wheel again and i will take photo's.
Not sure if everything is assembeled correctly, or even if all the parts are there.
thanks, marvin
marvin
