| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
10-18-2012, 02:10 PM
PA
Cobra Make, Engine: year 2000 SPF 351
New Balljoints
Thinking of changing out my SPF ball joints for cobra valleys Geometric correction ball joints any input thank you. Livnn
10-18-2012, 04:38 PM
I did mine last winter and the job went very well. The Cobra steers easier and the vibration is gone. You need to get the available tools for removal from CV as well. After that it would be a good time to set the road height and find a alighnment shop that can do a road force balance for you...Good luck
Glenn
10-18-2012, 04:54 PM
Do it. Once you pull out the factory ball joints only then you'll realize why you didn't do it sooner. They will be stiff as a rock and you'll have to beat on them in a vise to get them to move.
10-18-2012, 07:56 PM
CA
Cobra Make, Engine: Superformance SP3033, KC SBF 427
I went with the Ultra-Smooth version. They mostly (but not totally) eliminated some front shaking I was getting around 60 - 65 mph. They also eliminated some significant bump steer. Steering force seems about the same as with the factory joints (my car only has ~1700 miles on it). Haven't pushed the car hard enough to tell the effect on handling.
Matt
10-19-2012, 02:54 PM
OR
Cobra Make, Engine: Superformance Cobra Chassis #408, 427FE, TKO600
+1 on the Cobra Valley joints. The stockers are J.U.N.K.
Easier steering, no vibration, and just about eliminated bump steer.
Buy or borrow the tool to remove/install...makes it a very easy job. The hardest part was getting the new castle nuts tightened down to spec without twisting...just be careful with that, and know that you might need thicker washers (or stack them) to get the taper to engage. You may need to re-adjust ride height as well.
One of the best things I've done to #408 was replace those crappy ball joints.
06-25-2014, 04:31 PM
ny
Cobra Make, Engine: SPF
time to refresh this one.
.. Looks like I am in need of balljoints as well. The shake in the wheel when I get up to speed.
I did think I had a bad rim.. but with the new wheels and tires it is more pronounced.
Anyone else?
This appears to be the answer: Cobra Valley's R/T Super High Performance Ball Joints
06-25-2014, 04:51 PM
Il
Cobra Make, Engine: shell valley cobra-350 chevy
Do you know if these will fit a Shell Valley Cobra? Visually they look like they will.
Thanks, Russ
06-25-2014, 05:01 PM
Ca
Anyone else?
Before you jump in and replace the ball joints, take your wheels to a tire shop that uses the Hunter GSP9700 road force balancer and have your fronts done by a guy that knows what he's doing. Most front end vibrations are from out of balance or out of round wheels and tires.
Jim
06-25-2014, 06:02 PM
NY
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
I agree that Road Force balancing should be the first step. It must be done by someone knowledgeable with the machine and willing to take the time to get it right.
Then, if you still have the shake, RT ball joints are the way to go for all the reasons mentioned above.
Have fun and enjoy your car :-)
Jim Kellogg
Breesport, NY
07-10-2014, 01:03 PM
MA
Cobra Make, Engine: Superformance#1325, Miller Machine FE
Ball Joints
Best thing I ever for my Superformance. You still have to get a good balance job for the tires and wheels. The old bubble balance worked best for me. This is the direct link to the Cobra Valley site ball joints.
Everything has a downside, so dwell on the positives. Find humor in the tough times.
07-10-2014, 08:41 PM
ny
I see balljoints in my future
