Old 02-25-2013, 07:57 AM
Cobra Make, Engine: SPF 2046; P.E. Aluminum 427 Windsor.
Default Water Temp Sender
I have the Smiths water temp gauge. The sending unit is screwed into my Edelbrock Victor jr. intake manifold by use of a double male nipple fitting. The fitting works great with the sending unit but is the wrong thread size or pattern for the manifold opening. I suspect the nipple is metric whereas the manifold is tapped for SAE. I have been told to simply use a lot of teflon tape on the manifold side. I wonder if there is a better solution.
Old 02-25-2013, 08:18 AM
DanEC's Avatar
Is the manifold opening roughly the correct diameter but apparently another thread pattern - or is it much smaller in diameter than the fitting? I had to drill out and tap my FE Ford aluminum manifold with small opening, for the Smith gage fitting.
Old 02-25-2013, 09:46 AM
The hole in the manifold is larger in diameter than the fitting. It is a loose fit. Did you tap your manifold sae or metric?
Old 02-25-2013, 10:21 AM
DanEC's Avatar
Ohh - that was the opposite of my situation. I tapped in pipe threads - 3/8 NTP tap. I would think that is what your intake is tap'd for. But, I would also have thought most of the Smith gage sender adaptors were the same. Apparently not.
Old 02-25-2013, 03:32 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
I believe this is correct info for the adapter.
3/8" x 18 NPT to 3/8" BSP fitting.
SPFWiringDiagrams@Comcast.net
Old 02-25-2013, 06:16 PM
Thanks for the info. I'll try to find one locally.
Old 03-05-2013, 12:03 AM
PANAVIA's Avatar
Jim, you probably can find them online. -- try nissongers and or Pegasus.
Old 03-08-2013, 05:05 AM
Fred Hamilton's Avatar
I do beleive they use a crush washer on their Temp probe.
Fred
