| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
2Likes
Post By kennyhbh
Post By D-CEL
05-21-2013, 04:06 AM
NY
Cobra Make, Engine: SUPERFORMANCE #2258 402 S/R -ROUSH
MSD box placement
On superformance were should the MSD box be place?
Kenny
05-21-2013, 06:52 AM
GA
Cobra Make, Engine: Superformance 2729, 351W
Mine is in the passenger side footwell, mounted to the top of the footwell.
05-21-2013, 09:17 AM
Stolen Avitar
GA
05-21-2013, 11:36 AM
OR
Cobra Make, Engine: Superformance Cobra Chassis #408, 427FE, TKO600
Same....on top of passenger footwell box.
You can just see it in this pic:
(note the MSD tach box on the firewall)
05-21-2013, 05:23 PM
NV
Mine was on the driver's side footbox very close to the fender. I had to remove the air vent to get to one of the screws.
I replaced mine twice (one just before the shipper picked it up for the new owner) - I would have relocated it to the inside had I kept the car.
Tony
CSX4005LA
05-22-2013, 06:42 AM
PA
Cobra Make, Engine: Look-a-like cobra POS
Use the rubber isolation/vibration standoffs to keep it cool.
B. Ewing
05-22-2013, 08:31 AM
NY
from MSD
Dear Kenneth
The MSD 6 PN6420 can be mounted in the engine compartment. The only thing you want to keep the unit from is moisture.
Bass Chavez
Customer / Electronics Service Technician
Phone: 915-855-7123 Ext: 2279
Fax: 915-856-2706
E-mail:btc@msdperformance.com
Web: MSD Ignition
Please
Kenny
05-23-2013, 07:30 PM
CA
I am more of a fan of them in a cooler place, under that same area inside the footbox. -- they are a full 100F cooler there.
05-24-2013, 03:16 AM
Inside the car
Kenny my MSD 6AL is mounted inside the car under the glove box unside down with the chip hole facing out to swap easy if needed. Rubber mounted. 15 years, car has been in rain and major storms. No problem. Also have my ECU mounted in same place. I do have the foot air duct blow air to keep these units cooler than under the hood. 2 small tips, seal all seams with small bead of sealer,(clear) and electric dye grease on all connectors that might get wet or be near water. Rick L.
05-24-2013, 10:58 AM
ca
Cobra Make, Engine: SPF 239
Inside car, roof of the passenger foot box
05-24-2013, 10:03 PM
CA
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
D-CEL, why three boxes? Mine is the same position at the top of passenger footbox. Funny thing is that is right where I get the first water leak too. I think I better check the holes made to hold it in place!
05-27-2013, 01:17 PM
CA
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Mine is in the same place as D-Cell's. Located the MAP sensor there, too.
05-27-2013, 02:35 PM
CA
Originally Posted by kennyhbh
Dear Kenneth
Bass Chavez
Fax: 915-856-2706
Web: MSD Ignition
Please
The installer mounted my MSD box in the engine compartment on the passenger side wheel well. It's been there for 7 years, so I guess it passed the burn-in test.
Doug
05-28-2013, 06:16 AM
Fl
Cobra Make, Engine: Just a collection of parts right now...
I would keep it in the box on the shelf in the garage. Everyone I know that has run an MSD has had it fail...
05-28-2013, 07:19 AM
ca
Ward,
It’s only two! LOL, the red box on the right is an older rev limiter module. I run a fully redundant Ex-Winston-Cup system. Two HVC-6 boxes, two coils, rev-limiter, noise filter. It has a switch on the dash so I can change a completely different system. So If I’m out on the road and loose a box, just flip the switch and keep driving!
05-28-2013, 12:44 PM
Stolen Avitar
GA
I can only assume that you don't know a lot of people running them. I've run MSDs since the eighties (currently own 3 on running cars) and have never had one fail. Of course that doesn't mean that it can't happen but they're far from the guaranteed fail which you inferred.
05-28-2013, 03:29 PM
ca
I must agree with Lovehmr,
When I bought my car in early 2005 it had the SVO –Dura spark box in it and it was nothing but trouble, When I decided to end that misery and go MSD, I did the redundant thing because of all the bad press MSD was getting. It has been cool and makes diagnosis a snap, butI haven’t needed it as neither box has given me any trouble since installed.
IMO, the boxes longevity depends a lot on where you mount it, the farther away from heat and vibration the better. Inside the car on vibration isolators being best.
Jason
