November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By Mark IV
Old 05-29-2013, 02:09 PM
Cobrajames's Avatar
Cobra Make, Engine: SPF 2303, Titanium Silver, Roush 427 SR/TW, AED Carb, Firefly Sides, TKO 600
Default SPF handbrake/parking brake pads
Does anyone know of any options for purchase on the standard SPF handbrake pads (SUPERFORMANCE MKIII - HANDBRAKE PADS) for a 2007 built chassis #2303. I have been trying to get them from shopsuperformance through Hillbank for over 5 weeks but they are on back order. It is not their fault, but I need to get the job done. Thanks if you can help.
James
Old 05-29-2013, 02:33 PM
Cobra Make, Engine: Superformance SP02228, ROUSH 402R w/custom DiVinci Performance Carb.
Have you tried Olthoff Racing?
Home - Olthoff Racing
Old 05-29-2013, 02:35 PM
Senile Club Cobra Member
If those are the "crescent" shaped pads they are out of stock all over, I shipped my last sets to Texas and Qatar. I do have the round "Spot" type pads in stock as well as the discs.
You can however have them "relined"...find a good brake and clutch distributor and take the old pads to them. They can reline and re-rivet the new fricton material onto the existing backing plates. Be sure to check them against a flat surface, even new factory pads will have a "dish" and not have full contact with the disc. if they are not flat you can surface them on a sander. You will be amazed how much more holding power the brake has when all of the friction material meets the disc surface.
rick@autoventureusa.net
Old 05-29-2013, 06:07 PM
Cobra Make, Engine: superformance 1022
Rick are you referring to the hand brake that supposedly clamps onto the rear brake rotors? If the spot type will work let me know and I'll order a set. If not I'll try to get them relined. How thick should the material be. Tom from Sunday auto transport.
Old 05-29-2013, 09:43 PM
Cobrajames's Avatar
Thanks guys. Emailed Olthoff this evening. I don't know why I didn't already think of that. Otherwise, I guess I will just have to be patient and wait.
Old 05-30-2013, 04:23 AM
Tom,
They are 3/16" thick. The "Spot" type will only work with that type of caliper. I checked with Olthoff a week ago and they were out of the crescent type also.
These are for the driveshaft rotor type brake. The latest cars that use the Wilwood caliper with parking brake are totally different.
Old 05-30-2013, 05:16 AM
I've got chassis 1022 and the parking brakes are two small crescent shaped clamps(?) that are on the rear rotors. Are these the ones that can be relined? Any help is appreciated. Will keep the 2x4 handy. Tom
Old 05-30-2013, 05:31 AM
Any brake pad that is riveted to the backing plate can be relined. In the old days every shop had an arbor press for setting the rivets that held the shoe to the backing plate and you could commonly purchase just shoes to re-attach to your existing backing plates.
Just find a decent clutch and brake supplier, very common in most mid to large size towns.
jdmrestor likes this.
Old 05-30-2013, 05:38 AM
Thanks Rick! Tom
Old 05-30-2013, 09:54 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Tom,
You probably have the Wilwood SPOT parking brakes on your chassis.
I don't believe the pad material is connected to the steel backing plate on this parking brake. The pad material is free floating. You can use the backing plate as a pattern for the pad material shape if you have pads made. You them only need to fit the brake material so it does not bind in the housing of the SPOT caliper. I have a drawing of the actual pad. I had a few sets made years ago trying to find a pad compound that worked better. Cost was an issue with such a small run of pads being hand made, so I never followed thru with the project. Remember that if you do have pads made to match the backing plated, when you adjust the pad material with sandpaper - It's not healthy stuff to inhale.
From my notes:
Wilwood Caliper Parts:
Wilwood Spot Caliper Parking Brake:
150-5982 rear Parking Brake Pad
150-5983 rear parking Brake Plate
Behling Circle track
Butler, Wisconsin
1.800.255.4117
SPFWiringDiagrams@Comcast.net
Old 06-12-2013, 11:02 AM
Cobrajames's Avatar
I got my handbrake pads from Hillbank today. Thank you very much! Now I guess the fun begins on replacing the old ones with them.
