Old 06-30-2013, 05:58 PM
mattpatt's Avatar
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Question Muffler rattle?
I have this high pitched, metallic rattle (like a vibrating loose bolt against metal) from the right side when accelerating up through the RPM range. Haven't been able to find anything loose (seat bolts, side-pipe hangers, exhaust system connections, etc.). Almost sounds like the muffler is loose in the side-pipe and rattling.
Any advice?
Thx
Matt
Old 06-30-2013, 07:21 PM
CHRIS DAMSCH's Avatar
Cobra Make, Engine: SPF 1454
Check your timing. Could be detonation.
CHRIS
Old 06-30-2013, 08:22 PM
Cobra Make, Engine: SPF 2046; P.E. Aluminum 427 Windsor.
A few years back my baffles broke loose inside the pipes, first on one, then the other. Sounded just like you describe. Had to buy new sidepipes from the SPF dealer. Upside was that I was able to have Classic Chambered mufflers welded into the broken sidepipes. Now I have two sets. The stock set is stored for future use.
Jim
Old 07-01-2013, 04:08 AM
mickmate's Avatar
I think Jim's figured it. I have seen several mufflers crack around the end of the inside. I believe the difference in thermal expansion between the guts and the case causes this. You'll likely find the stock ones are really restrictive and a good muffler replacement like a Classic Chambered will free up quite a few ponies.
mickmate
http://www.actoncustom.com/
Old 07-01-2013, 09:53 AM
Send a message via MSN to CowtownCobra
You can drill and tap a couple of stainless screws on the lower inside section out of sight. No more rattles and a much cheaper and easier fix
Old 07-01-2013, 12:04 PM
mattpatt's Avatar
Thanks guys,
All good info. And I will check the timing too, just to be sure.
Old 07-05-2013, 07:53 PM
DanMartin's Avatar
Cobra Make, Engine: Superformance Cobra Chassis #408, 427FE, TKO600
I'm in exactly the same boat...my intent is to fix/upgrade the broken ones. I was fortunate enough to get a set from another SPF person on this site for cheap to replace the rattling ones.
