| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
1Likes
Post By jhv48
08-18-2013, 06:34 AM
NY
Cobra Make, Engine: SUPERFORMANCE #2258 402 S/R -ROUSH
Radiator cap ?
Hi Guys, I Owen# 2258 . i installed a recovery cooling tank to keep fluid off my garage floor. It seems that cooling fluid doesn't go back to to stock expansion tank. When i open stock tank there about !/4 inch fluid in the tank. the recovery tank never drains back. The engine runs at the right temp. , even on a 95 degree day. I'm running the stock cap do have change it out? also what lb. pressure cap should i be using? and what type of cap too.
Kenny
08-18-2013, 07:58 AM
Cobra Make, Engine: SPF#0760
Which recovery tank did you install?
The JAZ tank comes in two versions: Catch tank and a Recovery Catch/Recovery tank.
A photo would be helpful.
SPFWiringDiagrams@Comcast.net
08-18-2013, 08:36 AM
NY
HI, A Mr Gasket # 9135 Overflow and Recovery Tank
Kenny
08-18-2013, 08:42 AM
Ca
Neutral
Make sure you plumbed the hoses to the correct spouts. If reversed, it will fill, but not return to the system when pressure is relieved.
I looked at your recovery bottle and only find one inlet spout. And that one is up at the top. In order to be a recovery tank, it should have the inlet at the bottom and the overflow outlet near the top. This one just looks like an overflow catch can. Check out #9133. You'll see two spouts.
Jim
08-18-2013, 10:37 AM
Good catch !
08-18-2013, 02:52 PM
NY
Thanks for the info! Already order a 9133
Kenny
08-19-2013, 07:04 AM
NJ
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Regardless of the type of recovery tank that you use, you will need to swap out the radiator cap on the expansion tank to a recovery type, so that it allows the fluid back into the system. I believe the stock cap on the expansion tank is a one way cap which will allow the fluid out but not back in.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
08-19-2013, 05:08 PM
NY
What is the lb. cap should be use?
Kenny
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
