2Likes
Post By Blas
Post By CWizard
02-22-2014, 04:53 PM
Cobra Make, Engine: Superformance 351 Windsor
Odometer
My Mark III is 3 years old with 2500 miles, and I zeroed the trip indicator and now the trip or car odometer doesn't work. The speedometer works. I've reset the trip a couple of times, but neither works. Any suggestions?
02-22-2014, 08:33 PM
Tn
Cobra Make, Engine: Superformance#2352/Aluminum SO/490 c.i. 650 h.p. 605 tq.
Seems to be a common problem, mine is doing the same thing, I'm either going to get it rebuilt or get a new one.
02-22-2014, 08:48 PM
Check to see if the plastic plug behind the gear popped out. Mine did and stopped working. Had to push it back in and put some wire around it. It will be on the passenger side of the speedo.
Scott
02-22-2014, 11:53 PM
Cobra Make, Engine: SPF #1473 392 cu.in. titanium/black stripes
Ditto Scotter's post.
"Outside of a dog, a book is man's best friend. Inside a dog it's too dark to read."
Groucho Marx
02-23-2014, 01:04 PM
Cobra Make, Engine: SPF#0760
Zeroing while moving is a no-no.......
SPFWiringDiagrams@Comcast.net
02-24-2014, 06:45 AM
Checked and the white plug appears to be in place. I can still zero the trip indicator. If the speedometer has to removed, how much of a problem?
02-24-2014, 06:34 PM
TN
Cobra Make, Engine: SPF, 418 Stroker
Hardly any at all. The speedo is held in the dash be a U shaped bracket which is secured by two thumb nuts. Get a flashlight and mirror and have a look. Remove the nuts, the bracket falls off, and the speedo pops out the front.
02-24-2014, 06:47 PM
That speedo is a POS. I've never touched the odo for fear the thing is going to crumble inside. I replaced the cable once...still has a nice bounce to it. I keep threatening to replace it with an electronic speedo.
Doug
02-25-2014, 08:38 PM
MD
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Mine stopped dead on 20,000 there is a plastic gear inside the spedo that has broken/stripped a tooth or two!
B i l l
03-23-2014, 05:32 PM
I spoke with Kevin at Cobra Valley and he said someone has posted detail instructions for the replacement of the odometer gear. I have purchased the gear and am ready for the repair.
