| 29 |
1Likes
Post By Got the Bug
10-08-2014, 01:30 PM
MI
Cobra Make, Engine: Superformance #1309 www.spfowners.freeforums.net
How hard is it to put the top on?
I've had 3 SPF's and have never put my top on. How hard is it and how long does it take? Anyone have step by step directions?
10-08-2014, 02:42 PM
Senile Club Cobra Member
Buddy,
PM me, I will send you the manual. Not hard, just a frustrating when it is wet or cold. I can do a top in about three minutes.....when the top material is warm and supple...at 30 degrees it is another story!
rick@autoventureusa.net
10-08-2014, 05:08 PM
MI
Sent, just wondering if I should put my top on to extend my driving season.
10-08-2014, 05:17 PM
Only if Warm/Dry are factors!
10-09-2014, 02:52 AM
You could always have a beautiful female wrap herself around you  I would suggest, and Rick gave this same advice to me, that you take the top inside for a few hours to let it warm up before attempting to put the top on. They are harder to stretch when cold.
10-09-2014, 09:15 AM
ny
Cobra Make, Engine: Gary Edwards Racing 460
If you are anal about the paint be careful the top will flap around at speed and hit the paint.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
10-09-2014, 11:04 AM
nj
Cobra Make, Engine: Backdraft 1048
I have a Backdraft and install the top early November. I also have a heater and with both it helps keep the cockpit warmer but the windows let in a strong breeze that keeps you aware that it's cold outside. A heavy jacket and gloves are a must.
Backdraft 1048
10-14-2014, 08:36 PM
Cobra Make, Engine: SPF MKIII, Roush 427RRRR
I put my top on all the time. I put a strip of clear bra where the top sits on the paint. Cheep insurance for the paint. the heater works good but the top leaks cold air around the sides. It is awesome though. Its like a whole other car. Out in Arizona I get to drive year round.
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you finally have enough horsepower". Mark Donohue
10-14-2014, 10:34 PM
7 years later and mine is still in the bag that in came in. My guess is that it'll probably start to degrade at some point.
Doug
10-15-2014, 08:47 AM
Cobra Make, Engine: Superformance with Roush 427 R
mine still in original packaging too....keep the heat on and wear a hat!
10-31-2014, 08:35 AM
Originally Posted by Mark IV
Buddy,
Mark IV.
If you could be so kind as to share that same information with me it would be much appreciated. I am ordering the owners manual in the next couple of days but will not see it for some time I suspect.
I have sent you a PM....thanks in advance
11-01-2014, 06:55 AM
Originally Posted by mikeylikesit
Mark IV.
Done!
11-01-2014, 07:18 AM
Done!
Thanks, got it
11-01-2014, 07:25 AM
OR
Helped a friend with an SPF put his top on for the first time and, even without instructions, it wasn't hard to do. SPF does a good job with their tops and side curtains and the fit is pretty good.
I would advise doing it in the garage a couple of times so you get used to any quirks with your unit under good conditions. After that it should be a breeze.
Practice getting in and out over the pipes several times once the top is on for the first time. You might have to do some creative body folding but you'll get used to it.
The cars do have a different look with the top on. From some angles it looks even meaner.
DonC
11-01-2014, 05:29 PM
With a little effort the soft top can be made pretty weather proof. And it is like having a completely different car.
11-01-2014, 07:25 PM
I open the drivers door and crawl across to the passenger side then reverse myself into the drivers seat. I wouldn't advise doing that with a passenger unless you're really good friends with them, really you don't want to do this when anyone can see you.
11-02-2014, 05:23 AM
VT
I've been doing that same crawl for a month now! My top is 22 years old, ripped and held together with Gorilla tape but still gives me another month to drive and lets the heater actually heat things up a bit. I'll probably bite the bullet and have a new one made next year.
Tim
