Old 10-23-2014, 09:35 AM
Cobra Make, Engine: year 2000 SPF 351
Default Running a Manual fuel pump ?
I have an oil cooling set up on my 351 W the lines are very close to the area were the fuel pump would be. Thinking it might be too tight, anyone running a manual fuel pump with the oil cooler on their 351 W and know if this will fit in there with the oil lines? Thank you for your help
Old 10-23-2014, 09:51 AM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
My ERA with a 351W had an oil cooler and a manual fuel pump when I bought it from the first owner. Everything fit, but not much room in that area. Had to use a short oil filter to clear the frame. I removed the oil cooler because my oil temp was not getting much above 140F (I also have a large capacity Canton oil pan, 7 or 8 quarts I think). Without the oil cooler my oil temp is around 180F where it should be. Unless you are racing, the oil cooler is not useful. My $.02.
Old 10-24-2014, 05:26 AM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
My engine is an FE and I run a mechanical fuel pump and and oil cooler. The oil lines are very close to the fuel pump but has never been a problem.
Ted
Old 10-24-2014, 05:46 AM
Ron61's Avatar
Post
On my 351 I put in a remote oil filter and that took care of the having to use a short oil filter and also I ran an electric fuel pump so that gave me plenty of clearance in that area.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 10-24-2014, 08:37 PM
Rick Parker's Avatar
There is plenty of room with most chassis's. Aviaid makes a better filter adapter which I changed to, this one in the photo from Canton is quite bulky & heavy.
Rick
Old 11-01-2014, 06:29 PM
mattpatt's Avatar
Cobra Make, Engine: Superformance SP3033, KC SBF 427
I have a Dart aluminum block 351W in my SPF (3033). I used a mechanical pump and the Canton remote to the std Superformance remote filter location. Tight but it all fit.
Old 11-01-2014, 07:02 PM
Cobra Make, Engine: Backdraft #1371
How about a remote filter and a oil cooler thermostat?
Old 11-02-2014, 02:06 PM
*13*'s Avatar
289 with mech & sandwich adapter for oil lines. I run a WIX filter(very short), you won't find it listed anywhere. I can get part# if you are interested.
ERA FIA 2088
