Like Tree1Likes
  • 1 Post By Blas
Old 06-27-2015, 08:14 AM
Default Low Beams Not Working (first night drive)
Hello all, my new (to me) #1764's headlights don't come on at the third (bottom) position of the dash switch; they only come on with the turn signal's back switch clicked on-high beams, accompanied by a light on the dash...
Whats wrong?
Superformance 1764
Built 427W
Aiken SC USA
Old 06-27-2015, 08:39 AM
Wild guess is the button on the back of the turn signal switch to activate the high and low beams is weak. click it a couple of times.
Old 06-27-2015, 09:06 AM
Default I can definitely try that!
I dont even have to get out of my robe! (Sat AM lazy...)
Superformance 1764
Built 427W
Aiken SC USA
Old 06-28-2015, 06:00 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Replace the headlight relay before you do anything else.
Contact me if you have questions.
Blas
JBCOBRA likes this.
SPFWiringDiagrams@Comcast.net
Old 06-28-2015, 08:11 PM
DWRAT's Avatar
Could you simply have burned out low beams?
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 06-28-2015, 09:09 PM
Cobra Make, Engine: Superformance No. 1359 / 351
SPO1359 had the same issue. I found out the low beam lights did not work as I was driving from New Mexico to North Carolina. I replaced the headlight relay and the problem was solved.
Jamie
Old 06-29-2015, 10:42 AM
Listen to Blas ;-)
Had the same thing happen. Get a real VW relay not a fakiedoo. Tried that too. It lasted a week
Old 06-30-2015, 11:03 PM
Anybody have a source/part number? I am fairly certain there are quite a few VW headlight relay variants?
Thanks!
Superformance 1764
Built 427W
Aiken SC USA
Old 07-01-2015, 09:35 AM
I think this is the part number VW part DNI 0127
but Blas is the expert on Lectricty ;-)
Old 07-01-2015, 07:47 PM
Jim Kellogg's Avatar
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
The relay is a common point of failure, but I would start at the beginning.
Check all your fuses. I lost my low beams one time - had a bit of corrosion on the low beam fuse. Replaced the fuse and all was OK.
Hope this helps,
Old 07-01-2015, 08:31 PM
My goofy owners manual shows one transverse bank of fuses where the car has TWO longitudinal rows...Guess i pull them all (one at a time LOL)...The headlight relay seems to be a big aluminum affair just floating free in there??
Superformance 1764
Built 427W
Aiken SC USA
Old 07-08-2015, 09:10 PM
Replaced the headlight relay, no luck, checked all the fuses under the dash, all good? how does one remove the headlights to check for low beam volts?
Why is the search function so horrid on this site? It looks like the same architecture as others i use, but the search here is really hit or miss...
Superformance 1764
Built 427W
Aiken SC USA
Old 07-09-2015, 07:01 PM
Well i have a spare headlight relay; The headlights come off via a screw under the bezels; the sealed beams are just crummy old 6024 sealed beams, available at O'Reilleys for like a 10 spot each: Trouble was BOTH headlights had dead low beams...weird. Maybe fancier lights later but for now these will do.
Superformance 1764
Built 427W
Aiken SC USA
