Old 09-08-2015, 07:44 PM
Default Sheared off bleed screw refreshing fluid
Last screw of last caliper (inner drivers front) twisted right in half when going to loosen the inner 1/4 bleed screw (housing sheared in half) seeing as i was one man pressure bleeding it made quite the mess...
On searching the inter-web i came across some photos of bleed assemblies broken the same way...
Does anyone have a source for a replacement bleed assy (at least the outside)?
SPO 1764 2003, four piston dual bleed calipers x 4
Superformance 1764
Built 427W
Aiken SC USA
Old 09-08-2015, 08:18 PM
DWRAT's Avatar
Deleted
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 09-08-2015, 08:26 PM
DWRAT's Avatar
This looks real close. Wilwood High-Performance Disc Brakes - Flexline No: 220-0627
FFR MK1---Sold
No more Furds.
Old 09-09-2015, 07:56 AM
Cobra Make, Engine: SPF 1233-396C.I. Windsor
Neutral
You are looking for a 1/8" NPT brass bleeder assembly. Should be available in Weatherhead or Dorman product line, at your local parts store under $5.00. Wilwood also sells this as a repair part.
Mike Beamish / Northern Racing Products Superformance service & installation.
Old 09-09-2015, 08:26 AM
DanEC's Avatar
You might want to replace it with Dorman speed bleeders with thread sealant and an internal spring loaded valve. They make brake bleeding easier - especially if doing it yourself alone. I found them on the Dorman rack at Pep Boys so most similar auto stores may have them.
ERA 782 Running
Old 09-15-2015, 10:06 AM
For everyone's info: Summit has them, but prior to install you need to run a 1/8" NPT tap into the hole. The broken piece was easily easy-outed...
Summit part no. 002-0627:
http://www.summitracing.com/parts/wil-220-0627
$10.13 for four.
Superformance 1764
Built 427W
Aiken SC USA
Old 09-15-2015, 12:56 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Pegasus racing???
I get a lot of stuff from these guys - becasuse they have it.
Tru
