Old 04-11-2016, 10:48 AM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Default Swaybar upgrade
Any of you folks that have done the sway bar upgrade have any particular tips, setup suggestions, etc.
I know this is a pretty straight forward deal but thought I'd ask. Am getting the full set with all current upgrades.
The older I get, the faster I was.
Old 04-11-2016, 02:39 PM
buddyg's Avatar
Cobra Make, Engine: Superformance #1309 www.spfowners.freeforums.net
I got mine from performance unlimited and they were installed by Craig from Craig's cobras. Works great but not sure of the settings Craig used.
Superformance specific forum check it out!
http://spfowners.freeforums.net/
Old 04-11-2016, 03:59 PM
DWRAT's Avatar
I set mine up using the furthest holes and it does fine.
You can make it stiffer using the inner holes if need be.
The instructions say you need all 4 corners in the air but you can do the front and then do the rear separate if you want.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Rate This Thread:
