Old 06-21-2016, 11:56 AM
Just takes time and awkward arm and hand movements.
Determine the size once you remove it. Probably a Wilwood 7/8 master but the Best way to tell is to remove it and see. Different cars use a variety of sizes. Especially if the previous owner had to swap it out. Cost for the replacement kit is around $70. Everyone sells them online. Here's one from speedway. I think this is the one I replaced mine with. Been a few years. Wilwood Combination Remote Fill Master Cylinder Kit
Jim
Old 06-21-2016, 01:57 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
Thanks Jim.
I've done the slave two or three times, but the master hasn't been done. 45k miles and 13 years old. No to bad!!
Old 06-23-2016, 10:22 AM
scootter's Avatar
Thanks for the web site Jim. Neither Summit or Jegs sold the 7/8" bore in a kit or separate which is the one I have. Wilwood only sold it separate but was much more!!
Old 06-23-2016, 01:26 PM
Bernica's Avatar
Senior CC Premier Member
Try AFCO.
https://www.afcodynapro.com/
Old 06-23-2016, 01:40 PM
Don't forget to bench bleed it before installing it, or you could be chasing an air bubble when you finally do bleed the system.
Jim
