Like Tree1Likes
  • 1 Post By Andheeezonit
Old 01-05-2018, 03:34 AM
Default SP03174 Brake Master Cyl
While inspecting my new roller and getting it ready for the engine installation I found the brake master cyl leaking. The reservoir is almost empty. Fluid seems to be leaking at both of the rubber seals between the reservoir and master cyl it is mounted on. I’m thinking I need a new master cyl. All of this is tucked under the left front fender. Does anyone know if the master cyl can be removed from the booster with the booster in place? There isn’t much room to slide the master cyl forward.
Old 01-05-2018, 10:53 AM
Andheeezonit's Avatar
Cobra Make, Engine: Superformance. 427 Windsor.
I had the same problem with 3153. I ended up using hose barb to AN adapters and going with reproduction Girling resovoirs for both the brakes and clutch, mounted to the firewall. To answer your question, yes, it can be removed without removing the booster. There is an access panel in the fender well for this but it's still a chore. Good luck.
Old 01-05-2018, 11:29 AM
BTW, it's not your MC, it's the fit of the res barbs in the grommets. This problem was reported long ago to Hillbank, doesn't seem to have helped.
Old 01-05-2018, 07:16 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
res barbs in the grommets....???
SPFWiringDiagrams@Comcast.net
Old 01-05-2018, 07:34 PM
Reservoir barbs into the rubber grommets of the master cylinder, loose fit allowing leakage of the brake fluid from the reservoir. Only a problem if you like to be able to stop.
jeclarke likes this.
Old 01-06-2018, 02:12 PM
Thanks for the response!
Old 01-25-2018, 07:25 AM
Cobra Make, Engine: SPF 239
I went a different direction...
Old 04-13-2019, 03:22 PM
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Nice DCEL where'd you get that pedal setup? I want one...
Old 04-15-2019, 08:55 AM
[IMG][/IMG]Hey Mike
I built it all. (This is my second iteration) I used the stock SPF pedal and welded in a wildwood balance bar tube with some extra bracing added, the aluminum mounting plate puts the M/C’s at 60 degrees and uses the factor mount holes plus a couple extra. However, the fiberglass foot box wasn’t designed for this amount of load, so there is still flex.
My newest version is underfloor, hydroboost, dual M/Cs with a balance bar.
I have to keep myself busy! lol
1st try!
Old 04-15-2019, 03:04 PM
Nice Work! You'll have the best stopping cobra around if you keep that up!
Old 11-08-2020, 09:00 AM
WJB WJB is offline
Cobra Make, Engine: Superformance 427SR
My Master cylinder was trashed... Rust was so bad, the seals were leaking, and new seals were not going to fix it. Ordered a new MC. While waiting, fabricated a bracket for the Wilwood billet reservoirs. Tired of reaching under the fender to fill...
New master cylinder comes with 22mm x 12mm grommets... those will not work with the factory reservoir. The factory (Superformance one) looks to be sized for a 10mm grommet.
Master Cylinder info:
C-Tek Brake Master Cylinder Volkswagen 131.33206
15/16” bore
1.92” stroke
John B
SPO3181, Grey/Platinum Roush 427SR
