Old 02-08-2018, 06:36 PM
Default SP03174 Sidepipe Installation
Put the Roush 427SR in my new Mklll on Saturday. Spent all day today working on the sidepipes. I can’t get the rear attachment points on either pipe to be where it needs to be. The rear attachmrent point is 1” outboard and 1” to low from contacting the chassis point. The sidepipe to header flange is loose to get max adjustment snd I’ve tried moving the engine right/left, forward/back and up/down and can’t get them any closer.
Any suggestions? Do I need to force them (bend them) into position?
Old 02-09-2018, 03:02 AM
Senile Club Cobra Member
You may need to use a "wedge" spacer to move the pipe to the point you need. Rarely our installer partners need to psychically "tweek" the pipe to achieve a non-loaded mounting, however the wedge spacer usually resolves the issue. These work: New Page 1
rick@autoventureusa.net
Old 02-09-2018, 07:40 AM
Thanks Rick. I had seen these spacers awhile ago online but had completely forgotten about them. They look promising so I’ll contact Craig and ask about them.
Old 02-09-2018, 08:48 AM
Cobra Make, Engine: SPF 1233-396C.I. Windsor
I have used ratchet straps more than once to manipulate the pipes to get them where I need them.
Mike Beamish / Northern Racing Products Superformance service & installation.
Old 02-11-2018, 01:25 PM
How much have you moved the pipes to get them in the correct position?
Did you do this with the pipes cold? I’m still installing the engine.
Old 02-11-2018, 03:01 PM
John,
You would think hot would be better but in reality the temp you would need to really be able to easily bend the pipes would mean your engine is running so far off proper mixture that the motor will be junk! Cold with a ratchet strap will do it. We have covered the pipe and placed my, well ample curb weight, ion the pipe to encourage it to move.
Old 02-12-2018, 06:10 AM
This should easily "convince" your sidepipes to align. The misalignment you have is minimal to me.
Old 02-12-2018, 01:22 PM
My driver side pipe, at the rear attachment point needs to move in 1.5 “ (towards the trans) and up 0.6” to contact the chassis pad.
Old 02-12-2018, 02:16 PM
It takes very little effort to move a 16 gauge steel weldment almost 5' long. Maybe someone has a better solution but this works 100% of the time in my shop. You are not going to hurt it.
Old 02-20-2018, 04:51 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I'm not familiar with the sidepipes on a Superformance but on an ERA it makes all the difference in the world to loosen up the header bolts first, get everything lined up as it should be and then tighten the header bolts last.
