February 2026
Old 06-25-2018, 09:33 PM
Default RT sway bar kit installed
Beautifully made, very nicely packaged, and with great instructions...now to figure out the six possible settings!
A quick spin revealed a much more compliant feel if that makes any sense. All the ends are heim joints vs just compressed rubber bushings.
Steve h
1764
Old 06-25-2018, 11:13 PM
Gaz64's Avatar
I don't like the ground clearance issue.
Old 06-26-2018, 05:50 AM
Default Clearance
I think that may be a bit of an optical illusion from the photo; look at the rear in the distance, they are in reality about where the factory bars were...
Steve H
1764
Old 06-26-2018, 07:55 AM
Default Back looking forward
Kind of the same illusion, look in the distance at the front...
Old 06-26-2018, 09:15 AM
1795's Avatar
Where did you get the sway bar kit and what model is it?
Old 06-26-2018, 10:37 AM
Senile Club Cobra Member
Jim,
That is Randy Thomas's "R/T" brand for MK IIIs, will not go on the MK II. We can mod your bars to rod ends if you want to go that way.
rick@autoventureusa.net
Old 06-26-2018, 11:28 AM
Andheeezonit's Avatar
Cobra Make, Engine: Superformance. 427 Windsor.
Mark IV, can you tell me if the front hub bearings on a 3100 series SPF are running in oil? Thanks.
Old 06-26-2018, 11:46 AM
They are greased with hi temp bearing grease, not oil.
Old 06-26-2018, 12:12 PM
I ask this because I have a small but persistent oil leak coming from both hubs behind the 5 pin adapters. I could not imagine an oil bath bearing in this day and age so it must be the grease melting down. Time to pull them and see whats going on. My guess is that the grease that they used may not be so great. 700 miles on the car, might as well rebuild these too!
Old 06-26-2018, 01:07 PM
1795's Avatar
Jim,
Rick,
Thanks. May be something that I want to consider for a winter project. Made some adjustments today to get ready for Watkins Glen July 7-8.
Old 06-26-2018, 06:38 PM
Gaz64's Avatar
Steve H
1764
The rear would be ok if you drove over something, but the front will catch up with mechanical failure as the result.
As long as you are aware of this, you'll be fine.
Old 06-26-2018, 07:17 PM
Default If I were going over objects big enough to catch the bar...
The oil cooler and its housing would likely be dragging upside down under the car...that's the thing I worry about...especially parking.
Steve H
1764
Old 06-26-2018, 07:45 PM
Gaz64's Avatar
I'd say you'll be fine, as it sounds like you are aware of other low clearances.
Old 06-27-2018, 10:30 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
I don't think the RT bar projects any lower then the standard sway bar does below the car. The sway bar's position (relative to the ground) is set by the two poly mount rotating clips connecting it to the chassis and that is pretty much sets it for you. (The laws of physics says that two objects - bar & chassis -cannot occupy the same space at the same time)
Ideal setup I am told is sway bar and its arms parallel to cars A-arms and the linkages perpendicular to A-arms and sway bar. Never seen one meeting both parameters because you can tune the bar by adjusting the linkages connection point on the sway bars arms closer or farther from the bend to change the leverage.
You should eliminate the preload on the sway bar by making the final adjustments to the drop links with someone approximately the same mass as the owner sitting in the drivers seat. Don't think fuel load enters into the equation because the fuel tank is pretty much centered in the chassis and the fuel sloshes around some.
Blas
SPFWiringDiagrams@Comcast.net
Old 07-02-2018, 11:22 PM
Apex_speed's Avatar
Cobra Make, Engine: Superformance Mk3 with Roush 427R
Did you do the suspension as well or just the bars?
Also, I assume you have the R/T rear suspension mounts. I just put them on a 2,000 mile car with the upgraded 10MM bolts and found that both sides had sagged 5MM on the stock mounts. Pretty scary stuff!
Old 07-03-2018, 06:35 AM
Default Everything but the spindles...
Got his coil over set, front ball joints (probably the biggest improvement), rear upper mounts (SPF as you indicated are junk), rear upper a arm heim, and gen 3 bar set; everything from the Cobra Vally suspension catalogue short of the front spindles I think...car rides and handles much better than It did stock...
Steve H
1764
Superformance 1764
Built 427W
Aiken SC USA
Old 07-03-2018, 08:56 AM
Blas's Avatar
WOW.... looks like Tiny Tim will be getting that operation he needs for sure now.... "God bless us, every one!"
Old 07-04-2018, 12:12 PM
Varmit's Avatar
Cobra Make, Engine: Superformance#2352/Aluminum SO/490 c.i. 650 h.p. 605 tq.
I have his coil overs adjustable shocks, ball joints and rear mount. I'm installing his adjustable sway bars as we speak.
Question, on the rear sway bars, and the spherical joints, mine have and inward angle to them. Did that happen on your as well???
The Cannons don't thunder, there's nothing to plunder, I'm an over forty victim of fate
Old 07-04-2018, 05:42 PM
Varmit's Avatar
never mind I got the solution as to what I did wrong
