Like Tree3Likes
  • 1 Post By CSX 4133
  • 2 Post By rodneym
Old 07-01-2018, 11:51 AM
Default Turn signal adjustment
What’s the trick to keeping the turn signal adjusted properly? I take the wheel off and adjust the collar so it’s in the middle of the right and left turn “bumps”. Put it back together and it works perfectly for a few turns. Then it’s back the way it was. Left turn is fine. Right turn clicks off right away with the steering wheel straight ahead.
John 3174
Old 07-01-2018, 11:53 AM
Cobra Make, Engine: Superformance #678
Hmmmm exactly opposite of mine, I will watch this thread
Old 07-01-2018, 12:54 PM
Senile Club Cobra Member
SPF Turn Signal Adjustment
rick@autoventureusa.net
Old 07-01-2018, 04:15 PM
THanks, I just fixed mine.
Old 07-01-2018, 05:21 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Pretty simple problem that 'all too many' Cobras have.
I can't say I remember a retaining ring.
rodneym
Old 07-02-2018, 08:12 AM
Cobra Make, Engine: Backdraft Cobra RT3, Roush 427R Crate Engine, Tremec 6-Speed Transmission
Does the SPF Turn Signal Adjustment procedure listed above by Mark IV work for late model Backdraft Cobras?
Old 07-02-2018, 08:27 AM
No idea, but they use the same VW signal switch so I would assume possibly. We also supply a quality VW reproduction switch for under $100.00
Old 07-02-2018, 01:49 PM
I’ve used that procedure twice and the adjustment is perfect for only a few turns. Then its back the way it was.
What keeps the collar centered once everything is back together? I have a coil spring on the column but not sure what it’s supposed to be doing.
Old 07-02-2018, 01:57 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
There should be a nub screw on the collar that clamps down on the steering shaft. Sometimes they slip.
rodneym
Old 07-02-2018, 02:06 PM
We have had the slipping leaver mechanism slipping from day one. The set screw will not hold and is as tight as it can be, and will not come out to replace. Will get it fixed someday.
Old 07-02-2018, 03:06 PM
The procedure that Mark IV references uses the term “turn signal cancel lug”. One can rotate this lug to get good turn signal cancelation in both directions. Mine apparently easily moves out of position during use. What is supposed to keep it in the desired orientation? Is it the coil spring?
Old 07-02-2018, 06:04 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Take the steering wheel, cancelling collar and turn signal assembly off and you'll see marring on the steering shaft that the collar's set screw made.
Try drilling a little divot(?) in the steering shaft so the screw has a place to sit/grab and use some Lactate on the threads (of the collar).
Also, grease the fingers that pop out of the turn signal assembly (when you activate the lever) and the 'ears' of the collar.
rodneym
Old 07-02-2018, 06:43 PM
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
............."use some Lactate on the threads". I know what you meant though, Loctite. I imagine it might be hard to find a cooperative female. LOL !
rodneym likes this.
~ Steven
6S1806, 1966 Shelby GT350 B/P Race car.
6S246, Shelby GT350 "carryover"
6S1745 Shelby GT350
Old 07-02-2018, 07:08 PM
Rodneym - thanks for the explanation. I’m away from the car for the week but will follow your instructions when i return.
Old 07-02-2018, 07:19 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
I corrected the damned spellcheck TWICE and it still got away from me! Lol
1795 and CSX 4133 like this.
rodneym
Old 07-03-2018, 11:49 AM
Andheeezonit's Avatar
Cobra Make, Engine: Superformance. 427 Windsor.
My set screw would not stay tight on the column. I drilled and tapped for a larger diameter set screw. Has not moved since.If my memory serves, there was a small piece of metal between the set screw and the column. I removed this and turned the screw directly against the column.
