Like Tree1Likes
  • 1 Post By jhv48
Old 09-07-2018, 09:28 AM
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
Default Shock adjustment/ride height
I want to increase my ride height a bit I have tires rubbing over big swales in the road.
Does anyone know what the correct wrench(s) is and where I can buy it. A couple years ago I ordered a couple from Summit and they are not correct.
Thanks
Bill
Old 09-07-2018, 11:45 AM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Default speedway motors
https://www.speedwaymotors.com/Speed...Tool,2681.html
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
Old 09-07-2018, 02:38 PM
You may not like the look of the car after you raise the ride height.
I experienced much the same thing and ended up replacing all four shocks and springs with adjustable shocks and heavier springs.
The ride height remains unchanged, but the handling and bouncing have dramatically improved.
Ron61 likes this.
Jim
Old 09-10-2018, 07:11 AM
Default I don't want to take it up a lot
The car was not rubbing and now it does occasionally. Its pretty low so I think I can take it up a bit without changing the look drastically and stop the rubbing.
Thanks for the reply.
Bill
Old 09-10-2018, 10:31 AM
Sawdust's Avatar
Bill - FYI
The proper ride height for SPF Cobra's are 22 1/2". Measured from the centre of the bottom lip of the rim to the centre of the fender
Old 09-10-2018, 10:58 AM
Default Is it a single number?
I am running 18" wheels.
The link I provided show ride height by rim size.
https://superformance.org/scof_tech_...alculator.html
Bill
Old 09-10-2018, 02:54 PM
Sawdust's Avatar
Looks like 24" is your magic number. Didn't realize you are running 18" wheels. Good luck!
