Like Tree1Likes
  • 1 Post By twobjshelbys
Old 03-15-2019, 09:21 PM
Cobra Make, Engine: Superformance spo2815 roush 427sr polished
Default sbf stroked 351W Roush 427R water pump
anyone knows which pump Roush used for their crate 427R motor?
Old 03-16-2019, 08:42 AM
twobjshelbys's Avatar
Mine died on me and he just got a 351w pump from Autozone.
ront49 likes this.
Tony
CSX4005LA
Old 03-16-2019, 11:41 AM
Sawdust's Avatar
Any pump manufacture will work as long as it's for a 351W
Old 03-16-2019, 03:31 PM
Roush usually uses Edelbrock CW (clock wise rotation) water pumps.
Polished is PN 8848 to match your motor.
Page 209 in the catalog
https://edelbrock-files-v1.s3.amazon...ck-Catalog.pdf
https://www.summitracing.com/tx/parts/edl-8848
Old 03-19-2019, 05:15 AM
Default Water pump
How do they die? Bearing noise? Water leaking? Just curious what to watch/listen for...thanks
Steve H
Superformance 1764
Built 427W
Aiken SC USA
Old 03-19-2019, 07:14 AM
It can be either the bearing (with noise) or a shaft seal leak.
6 Signs You May Have a Bad Water Pump
Most pumps have a weep hole at the 6 o'clock position.
https://sciencing.com/there-small-ho...p-5187372.html
Old 03-19-2019, 09:46 AM
Thanks! I believe mine has a hole near the top?
Superformance 1764
Built 427W
Aiken SC USA
Old 03-21-2019, 06:42 AM
Cobra Make, Engine: SPO 3061 Roush 427SR
My 427sr motor had a Weiand pump on it. I replaced it with a Ford Racing unit. Watch out for the bypass/radiator pipe fittings, the may be different and require some plumming changes due to size issues.
Old 03-24-2019, 08:26 PM
shaft seal leak without warning, replaced it with PRW polished pump which came with the Roush 427R. Amazon shipped it to Hawaii in 4 days.
Rate This Thread:
