| 29 |
6Likes
2
Post By Mark IV
Post By tortuga
2
Post By twobjshelbys
Post By Blas
11-05-2022, 02:03 PM
Cobra Make, Engine: Superformance # 1774 / 392 Stroked Windsor
Blinker, hi-beam lever question?
Anyone know the part number or where to get info for the hi-beam blinker switch and the headlight switch? I know you can get several of the parts at NAPA. The car is a Mark III Superformance # 1399 Thanks, Mark
11-05-2022, 03:38 PM
Cobra Make, Engine: SPF832, 466cid
Turn Signal Switch JOPEX 8196200800
They're everywhere on the web at various prices.
11-05-2022, 04:19 PM
Cobra Make, Engine: SPF#0760
Before replacing that part, what is the problem exactly you are having?
Blas
SPFWiringDiagrams@Comcast.net
11-06-2022, 04:02 AM
Senile Club Cobra Member
There are several manufacturers of this switch, some are outright junk, others are pretty good. We have found a supplier that has a unit that we feel is better than the Superformance factory supplied switch.
rick@autoventureusa.net
11-06-2022, 12:09 PM
Its a VW bug unit.
As blas asked what is the issue...I just went through this whole evolution...
Steve H
1764
Superformance 1764
Built 427W
Aiken SC USA
11-06-2022, 12:52 PM
Is the JOPEX junk? Is it the one supplied by the factory?
11-06-2022, 01:04 PM
NV
It's just off a 60's VW bug. What magic floobie dust would make any one better than any other?
CSX4005LA
11-06-2022, 05:23 PM
I’m still waiting to hear what the actual issue is.
Blas
11-07-2022, 12:47 AM
Like being one that doesn't fall apart when used? That doesn't have the hi beam switch lock-up? That magic floobie dust........
Not personally familiar with the JOPEX. The factory switch is decent but there are better ones available up to a $350 plus "super repro" VW switch.
11-08-2022, 06:06 PM
NC
Cobra Make, Engine: Superformance Mk III
To jump on this forum. I also am looking to replace the turn signal lever.
My specific issue is the switch on the back of the stock itself has broken off and the relay inside of it is stuck in the ON position. Not too bad since I don't drive at night but definitely want to fix this with an OEM or better part.
Robby Hayman
11-09-2022, 06:37 AM
Robz,
You have a message
Blas
11-28-2022, 08:07 PM
My issue:
When signaling to turn left, I must hold the blinker lever in position
Any suggestions on how to correct?
11-29-2022, 04:33 AM
Originally Posted by Michaelanezinis
My issue:
What make is your car? If Superformance we can supply instructions on the repair.
11-29-2022, 09:32 AM
Sounds like it might be the internal cancel cam mechanism that needs an adjustment.
Send me a message or email and i can get the procedure to you.
Blas
12-01-2022, 06:21 PM
It’s a Superformance
12-02-2022, 03:40 AM
PM me for the information
12-13-2022, 03:03 PM
Thanks guys. The clicker on the blinker switch was sticking bad. Got a new one. Everything is ok! Mark
03-07-2023, 09:28 AM
Cobra Make, Engine: SPF MKIII, Roush 427RRRR
My high beam low beam switch is stuck in. Can I pull it apart and fix it or should I just replace it?
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you finally have enough horsepower". Mark Donohue
03-07-2023, 09:51 AM
Cobra Make, Engine: Superformance-Port fuel injected 427 stroker.
We have a high beam switch, lol.
2003 SPF 351W/427 stroker with port fuel injection. Royal Blue and Polished 17's.
