Like Tree6Likes
  • 2 Post By Mark IV
  • 1 Post By tortuga
  • 2 Post By twobjshelbys
  • 1 Post By Blas
Old 11-05-2022, 02:03 PM
TN Shelby Cobra's Avatar
Cobra Make, Engine: Superformance # 1774 / 392 Stroked Windsor
Default Blinker, hi-beam lever question?
Anyone know the part number or where to get info for the hi-beam blinker switch and the headlight switch? I know you can get several of the parts at NAPA. The car is a Mark III Superformance # 1399 Thanks, Mark
Old 11-05-2022, 03:38 PM
Cobra Make, Engine: SPF832, 466cid
Turn Signal Switch JOPEX 8196200800
They're everywhere on the web at various prices.
Old 11-05-2022, 04:19 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Before replacing that part, what is the problem exactly you are having?
Blas
SPFWiringDiagrams@Comcast.net
Old 11-06-2022, 04:02 AM
Senile Club Cobra Member
There are several manufacturers of this switch, some are outright junk, others are pretty good. We have found a supplier that has a unit that we feel is better than the Superformance factory supplied switch.
rick@autoventureusa.net
Old 11-06-2022, 12:09 PM
Default Its a VW bug unit.
As blas asked what is the issue...I just went through this whole evolution...
Steve H
1764
TN Shelby Cobra likes this.
Superformance 1764
Built 427W
Aiken SC USA
Old 11-06-2022, 12:52 PM
Is the JOPEX junk? Is it the one supplied by the factory?
Old 11-06-2022, 01:04 PM
twobjshelbys's Avatar
It's just off a 60's VW bug. What magic floobie dust would make any one better than any other?
TN Shelby Cobra and msinc like this.
CSX4005LA
Old 11-06-2022, 05:23 PM
Blas's Avatar
I’m still waiting to hear what the actual issue is.
Blas
Old 11-07-2022, 12:47 AM
Like being one that doesn't fall apart when used? That doesn't have the hi beam switch lock-up? That magic floobie dust........
Not personally familiar with the JOPEX. The factory switch is decent but there are better ones available up to a $350 plus "super repro" VW switch.
Old 11-08-2022, 06:06 PM
Cobra Make, Engine: Superformance Mk III
To jump on this forum. I also am looking to replace the turn signal lever.
My specific issue is the switch on the back of the stock itself has broken off and the relay inside of it is stuck in the ON position. Not too bad since I don't drive at night but definitely want to fix this with an OEM or better part.
Robby Hayman
Old 11-09-2022, 06:37 AM
Blas's Avatar
Robz,
You have a message
Blas
Old 11-28-2022, 08:07 PM
My issue:
When signaling to turn left, I must hold the blinker lever in position
Any suggestions on how to correct?
Old 11-29-2022, 04:33 AM
Originally Posted by Michaelanezinis View Post
My issue:
What make is your car? If Superformance we can supply instructions on the repair.
Old 11-29-2022, 09:32 AM
Blas's Avatar
Sounds like it might be the internal cancel cam mechanism that needs an adjustment.
Send me a message or email and i can get the procedure to you.
Blas
msinc likes this.
Old 12-01-2022, 06:21 PM
It’s a Superformance
Old 12-02-2022, 03:40 AM
PM me for the information
Old 12-13-2022, 03:03 PM
Thanks guys. The clicker on the blinker switch was sticking bad. Got a new one. Everything is ok! Mark
Old 03-07-2023, 09:28 AM
2Torqued's Avatar
Cobra Make, Engine: SPF MKIII, Roush 427RRRR
My high beam low beam switch is stuck in. Can I pull it apart and fix it or should I just replace it?
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you finally have enough horsepower". Mark Donohue
Old 03-07-2023, 09:51 AM
Cobra Make, Engine: Superformance-Port fuel injected 427 stroker.
We have a high beam switch, lol.
2003 SPF 351W/427 stroker with port fuel injection. Royal Blue and Polished 17's.
