Like Tree1Likes
  • 1 Post By patrickt
Old 02-24-2023, 08:01 PM
Cobra Make, Engine: Superformance-Port fuel injected 427 stroker.
RV2 -- If you are a big boy, and nobody but you ever drives your car, you might consider mounting your seat directly to the floor with new holes, all shimmed to fit your liking perfectly. A slight elevation to the front, while moving the seat down and back, will give you a surprising amount of extra room.
5-11 175 so not really a big boy. Was pushing 225 at one point and that qualified, LOL. I like the front of the seat as high as possible and the rear as low as I can go normally. I like your idea. Will play with it more. Hell, I was poking around back there and found a set of mounted Tri Axel Speakers. Hidden on the floor built in behind the seat. I found spliced wires under the glove box so I figured they had a radio mounted inside at one point but must have pulled it. Can you hear anything but side pipes in a Cobra? Hidden really well. Seen the ones mounted up high which would be better but looks too modern for me.
Have ramps coming to get under her easier and safer. Missing my buddies lift already. Going to try cleaning and working the slider first if not just direct mount.
Rate This Thread:
