Like Tree4Likes
  • 2 Post By 1795
  • 2 Post By mr bruce
Old 04-24-2023, 10:47 PM
Default Information on owner builds for a MkII
I originally wanted to build an FFR Roadster but now I am looking at a MkII slabside. I see most get their cars finished at a shop but I am wanting to do the work myself.
Is there a manual for this model that I can look at and see what is involved and what other parts are not included that are needed for installation? EFI vs Carb installation, wiring harness, etc.
I haven't been able to find any pictures of the Mk II chassis, suspension, or really anything to see what is underneath the body of these vehicles, can someone provide me with a link?
I'd really like to know what parts are used on these cars. What brakes, axles, etc.
Any help would be appreciated.
Old 04-25-2023, 03:44 AM
xb-60's Avatar
Originally Posted by islandvobra View Post
….. I am looking at a MkII slabside….
When you say “a Mk II”, are you talking about a Superformance car?
Oh, and welcome to the forum!
Glen
Old 04-25-2023, 06:18 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
The Superformance MKII’s have and owners manual package available for them. Included in the Owners Manual package is a Service Bulletin document which has a lot of additional information to make the drive train installation process easier, along with general maintenance information. You also get a complete Wiring Diagram in the package. Every Manual is custom made for each individual chassis. The Manual Package is also available for previously owned cars should the current owner be interested in owning a copy. Because there are so many choices for the engine components, that information is usually included with the engine by the installer or engine builder. There is a document included in the manual package for the owner to fill in the information for the drivetrain components used. And there are two different recommendations for transmissions identified.
Blas
SPFWiringDiagrams@Comcast.net
Old 04-30-2023, 06:15 PM
Glen
Yes, a Superformance MkII
Old 04-30-2023, 06:16 PM
Blas
Thank you for the information. Is there a manual or any literature that lets me know what all is needed to complete the build before purchasing?
Old 05-01-2023, 12:01 AM
xb-60's Avatar
...Is there a manual or any literature that lets me know what all is needed to complete the build before purchasing?
If you talk to the Superformance dealer, and he knows that you are interested in purchasing, I'm assuming that he would be forthcoming with build information?
Cheers!
Glen
Old 05-01-2023, 12:05 AM
xb-60's Avatar
islandvobra - I see that your location is listed as GU. Is that Guam?
Glen
Old 05-01-2023, 07:19 AM
Blas's Avatar
Off the top of my head:
Engine Assembly
Engine Mounts
Transmission Assembly
Trans Mount
Transmission Fluid
Clutch Assembly / Thrown Out Bearing / Bolting
Clutch Slave Assembly / Braided Hose / Adjuster Rod Assembly / Bracket
Bell-housing / Alignment Pins / Engine Plate
Drive Shaft Assembly (custom length) & Bolting
Ignition System with Coil & Mount
Alternator & Brackets and Bolts
Brake Fluid (for Clutch)
Misc. Bolts-Washers-Nuts
Exhaust Bolting (opt. Ceramic coating)
Battery & Battery Mat & Insulating Pad
Starter
Intake Manifold Mounting Plate
Double Carb Return Springs
Carburetor & Air Cleaner & Fuel Filter(s)
Fuel Pump & Hoses (opt. Pressure Regulator)
Misc. Sizes & Lengths of Wire and Connectors
Rubber / Metal Hoses / Clamps / Water Pump
Coolant / Thermostat
Oil / Oil Filer / Oil Filter Block / Cooler Hoses (optional)
Emblems (optional)
Blas
Old 05-01-2023, 02:16 PM
Senile Club Cobra Member
But, hey why ask a dealer who can answer the questions when you can go to a forum and have everyone give you an opinion.?!?!
rick@autoventureusa.net
Old 05-01-2023, 07:25 PM
Glen
Yes, Guam
Old 05-01-2023, 07:31 PM
I guess because forums are convenient, with thousands of people who are (usually) willing to help answer questions. I see none of these answers on the Superformance website so I figured I'd ask some of the owners.
Not to mention I live on the opposite side of the world and I don't have a dealer in my part of the world.
Old 05-01-2023, 07:33 PM
Engine Assembly
Engine Mounts
Trans Mount
Transmission Fluid
Starter
Emblems (optional)
Blas
Thank you, Blas for the information, much appreciated.
Old 05-02-2023, 04:12 AM
We can supply pictures of the chassis and whatever you may need. I personally have a MK II street roadster (hate the "slabside" moniker).
Old 05-04-2023, 03:27 AM
Cobra Make, Engine: Superformance Mk II 289
Let’s not pretend the dealers know everything.
Old 05-04-2023, 03:33 AM
1795's Avatar
It depends on the dealer and how long they have been in business and the extent that they have been involved in working on cobras. Some are quite knowledgeable.
Jim
Alfa02 and Gpfarrell like this.
Old 05-04-2023, 04:45 AM
and MARK IV is
Alfa02 and nkb like this.
Tags
mkii
