8Likes
5
Post By Tommy
3
Post By Tommy
04-27-2023, 04:18 AM
Manifold and hood clearance help
Hi All,
Novice newbie here with another question…
I’ve decided to go with the ford racing long block and dress myself. It uses the M-6010-boss35195 block. The deck height on this block is 9.5 and plan on running a 750 normally aspirated carb. Tom from ford racing recommends the Victor junior for best performance but wasn’t sure about hood clearance.
Would anyone be able to tell me if this set up will work for the SF MKIII in terms of hood clearance? Got a call into SF but still waiting to hear from them.
Thanks loads and I hope my question and ignorance isn’t too stupid and apparent.
04-27-2023, 04:44 AM
AL
David, I can't answer your specific question but I do have some things for you to consider. When someone "recommends the Victor junior for best performance," what kind of performance are you expecting? Do you plan to do track day events with your car? Is it just for cruising on public streets? Are you a drag racing enthusiast? . . . This matters because a Victor Jr manifold is optimized for operation above 3500 RPM. That's great for track use where peak horsepower matters, but not very good for street use where torque and responsiveness are what matters to most drivers.
It's been my experience that many engine builders want to sell cars with big peak horsepower numbers because it sounds impressive and helps bring in more customers. But those engines are not as much fun to live with in a street car. So, when deciding what components will best fit under the hood of your car, don't let your desire to own a big HP number make the task more difficult than it has to be. Let the engine builder know how you want to use the car and you may find that a low rise, dual plane intake manifold is the best overall solution. IMHO.
Tommy
Previously owned EM Cobra
04-27-2023, 10:21 AM
Thanks for the great info, Tom is the guru at Ford racing, since it’s a long block, ford racing did the build. Maybe I miss understood Tom.
I’m looking for a very friendly street drivable car with maybe a little auto cross at the local parking lot course on a weekend, so with that said possibly an air gap? I’m still reading, researching, learning and having fun with this new hobby.
Thanks loads for the advice
Ford says the LB is set up to run best between 3000 and 5600 rpm. The cam they use is probably a little aggressive for my needs but I don’t want to be changing things until it try them, it’s got 242/248 deg at 0.05” with 0.594/618 lift. Scat
04-27-2023, 10:36 PM
OR
Cobra Make, Engine: Superformance SPO2512 427W TKO 600/ NW Exotics 351 Cleveland/Tremec 3550-Sold
What size motor? You won't go wrong with a Performer RPM Air Gap manifold over a Victor Jr., especially in that RPM range. Bottom end is better and it gives up nothing in the top end.
I think the Air Gap and Victor Jr. are the same height at the carb mounting flange.
The Air Gap will fit under the hood with the supplied air cleaner baseplate if you're using the short air filter and the oval Cobra air cleaner.
The Air Gap will fit under the hood with the 2.5" tall K&N air filter and the oval Cobra air cleaner, but I did have to fab a flat air cleaner base plate to move the air cleaner assembly forward to fit. My motor was not happy at all when I tried using the short filter on the dyno.
04-28-2023, 11:04 AM
CO
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
I went with the Victor Jr. and Sniper Stealth EFI and am super happy I did. it is the same height as the Air Gap and performance is awesome, plenty of low end power, no hesitation and 20 to 30 more HP at higher RPMs.
04-28-2023, 12:21 PM
Randall at RT told me to stick with the vic Jr on my 427r.
He said the higher flow of the motor would need it even at lower rpms.
Mine clears the hood, but I had to run an air cleaner with more clearance.
I got one of the K&N units that sits on a metal riser, and used a rubber mallet to beat the riser nearly flat.
Acton sells a drop base for that size which makes it easy if you don't feel like an afternoon of careful hammering (and theirs has another 1/4-1/2" clearance)
04-28-2023, 12:43 PM
NV
Cobra Make, Engine: Shelby CSX48xx from South Africa
I like the looks of the super vic jr.
04-28-2023, 02:56 PM
CO
Here is the Holly Stealth EFI on the Vic Jr, the cool thing is all the EFI wiring was able to be hidden under the manifold runners. Used the very low profile '67 corvette bottom and a Holman Moody top.
04-28-2023, 05:07 PM
AL
Big intakes and little air cleaners never made sense to me.
Tommy
04-29-2023, 11:48 AM
Senile Club Cobra Member
The little "Stellings and Hellings" type air cleaners typically take about 30-50 HP compared to a regular air cleaner.
rick@autoventureusa.net
05-01-2023, 08:42 PM
I have a 514 with the Blue Thunder, 950CFM and about 3/4" of spacers and heat shields stuffed under the hood. I have maybe 1/2" of clearance.
