| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
10-13-2006, 05:47 PM
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Correction...two ears...not two full revolutions...my apologies. I had been hammering mine on way too hard when Dennis O showed me it only needs a couple of ears turn once it makes contact. You'll hear the sound change when the wheel bottoms out on the adapter. I've had #770 for 6 years now and never had a problem removing my knock offs or wheels.
No...I didn't record it, nor write it down... But, I've been privy to pretty much the same speech from Bob with at least four or five different owners who - for one reason or another - just couldn't get the hang of lefty-righty-righty-lefty. One poor fella...who shall remain nameless...worked for several months to remove a knock off with only a dead blow hammer! When another SPF owner visited him, he took hs own lead hammer and had the knock off removed in less than 15 minutes!
I sure miss Bob...he had forgotten more about these cars than most of us will ever know! He was truly one of a kind!
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
10-14-2006, 05:59 AM
NY
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by Flyin_Freddie
Safety wire should be installed as if it were trying to pull the knock off loose...not trying to prevent it from loosening. In this manner, you can check the wire for slack...indicating the knock off has loosened...and then whack your knock off a couple of time with your lead hammer to retighten it.
Bob Olthoff
Mmmm...This is contrary to what I've been told, and seen on cars from assemblers like HRE, Snakepit, and his son Dennis' shop. I was told safety-wire to prevent loosening with a bit of slack, and check before every ride. Evidence of tightening requires a whack to the rear and re-wiring.
In fact, ERA has the procedure on their site: http://www.erareplicas.com/427man/wheels/index.htm
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
10-14-2006, 06:28 AM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
I always wire with a bit of slack so as to indicate loosening. That being said, I've never had a spinner loosen. As a matter of fact, if they're are left alone for too long, they become welded on.
Bob
02-23-2009, 06:38 PM
MD
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Get in the glove box and read the owners manual!
02-24-2009, 02:18 PM
It`s a bit tight in here. Can I read it in the trunk rather?
Ross
02-24-2009, 05:16 PM
It's Slowwwwwwwwwwwwwwwwwwwwwwwwww........
You know it's slow when you guys resurrect a two and half year old thread on which way spinners tighten.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
