10-27-2006, 03:46 AM
Cobra Make, Engine: SPF#2189
"Polished Stainless Side pipes"
Who makes the best for "Superformance" IE: performance, fit, finish and looks. Websites would be appreciated.
TIA,
Steve
10-27-2006, 08:14 AM
Az
I got mine from Stainless Specialties in FLA.Their pipes were patterned from stock SPF pipes.
Last i knew,they came in two flavors-loud & louder.
Here's their address.I guess they moved to Tenn.
http://www.stainless-specialties.com/
10-27-2006, 10:41 AM
Il
I would suggest that you contact Ron Roberts, a fellow SPF owner. He makes a set of exquisite pipes and cuts no corners, they are a work of art. If you are a SCOF member you can contact him through there. If you aren't post here for him or PM me and I'll have him contact you.
WDZ
10-27-2006, 11:39 AM
MI
Cobra Make, Engine: Superformance Cobra SC, 514CID
Here is Ron Roberts Web Site, pics of his pipes and a phone number
http://buckshotracefab.com/
Craig
10-27-2006, 03:42 PM
Il
Thanks Craig, I couldn't remember the name when I posted earlier. I remembered later in the shop and was going to post it, but you beat me to it.
WDZ
10-28-2006, 08:07 AM
Thanks all so far, anymore??
Steve
10-28-2006, 08:36 AM
CA.
Cobra Make, Engine: Superformance, #930, 351W/427CID 419 RWHP (before the Webers!)
I went with the "loud" Stainless Steel Specialities" pipes because they fit my limited budget. Seat-of-the-pants dyno says they improved performance. They look great and have not turned yellow.
Only drawback for me is they have a very slight downturn at the tips which can really pi??-off the '32 Ford  parked next to you at the car show when someone asks you to "fire-it-up" so they can hear your engine and you blow gravel all over the '32.
If I went with them I'd ask if they can make sure the tips are 100% perpendicular to the ground. Just my thoughts.
Whichever way you go, you'll be glad you did.
Best
Terry Brown SPF #930 427W 419 RWHP 48 IDA Webers
"Remember, your car will not be more valuable after Track Day than it is the day before the event" - Eric W. instructional presentation on Track Day safety, 05/15/2008 WSCB
10-29-2006, 09:12 AM
Cobra Make, Engine: SPF 2046; P.E. Aluminum 427 Windsor.
Terry,
When you ordered from Stainless Specialties, did the sidepipes come ready to bolt up to your SPF? Also, I've heard that polished ones run hotter than ceramic coated ones. Any paint problems from the heat?
10-29-2006, 05:08 PM
CA.
Jim:
Bolted right on. No apparent heat problems. Did have to drop the right motor mount a little bit but it was not a big issue. I think my out the door price was around $2500 but I ordered some extreme heat shields which extend from in front of the mufflers to within 6" of the exhaust tip. I believe their pipes alone price is under $2000.
I couldn't be more pleased with the exception of the tip being very slightly tipped down. Not a problem visually but it does scatter gravel, dirt, leaves, etc  !
Terry
10-29-2006, 05:13 PM
CA.
Jim:
You will also have to attach the rear mounts to the muffler/pipe to connect to the frame. I had my local welder use the original brackets and weld them on after the pipes were mounted.
You should also consider having O2 sensors installed by the pipe manufacturer. Makes it much more efficient when you go to the dyno or use an O2 meter. I think about $25 ea. I think they take an 18mm pipe plug when not in use.
Just some thoughts.......
10-30-2006, 07:47 PM
Thanks for the info Terry.
I'm on the fence. I think improved performance and a more aggressive exhaust note would be fun but I can barely hear my passenger as it is.
I just don't know.
10-30-2006, 11:01 PM
I just don't know.
Jim,
It's a Cobra. Really, its okay to have fun and save the conversations for the other car. And, yes, you do know, the question never goes away, it just keeps resurfacing till you do it. Hahahahah.
Duane
10-31-2006, 06:03 PM
CA.
10-31-2006, 07:31 PM
MI
VERY nice Terry!!!!
Craig
10-31-2006, 07:38 PM
Originally Posted by decooney
Jim,
Duane, I think you're right. It's seems inevitable. I may as well give in now and up the grin factor a bit.
Terry, all I can say is:...sweeeet!
11-01-2006, 04:51 AM
Terry,
Those are indeed NICE.........
Steve
02-19-2007, 10:20 AM
Cobra Make, Engine: Superformance 460 SVO
Terry, did you have to lower the engine mount to install the sidepipes or did you have to lower and leave it lowered to fit??
Mel
02-19-2007, 02:23 PM
I like mine from www.buckshotracefab.com
Here they are with 17 inch wheels on the car.
Here's how they look in motion with 2100 ft air.
Buckshot Racefab side pipes in motion
Here's a recent dyno chart
475.3 wheel HP
If you get some I should mention the new pipes required an additional 3 jet sizes up primary and secondary to maintain the same air fuel ratio as the Superformance side pipes.
02-19-2007, 03:46 PM
CA.
Mel:
I had to leave it lowered. It was only one side and it was the beefier Olthoff replacement.
I understand the Stainless Steel Specialties drop the tips very slightly to focus the increased sound away from the driver/passenger.
Hope that helps.
02-19-2007, 04:11 PM
Terry thanks for the info, don't know if I could lower my mount, pretty tight fit as it is
Greg are those the two piece sidepipes, which pipes are they,, the street, or performance ones, your vid sound great
